Tip & How-To about Computers & Internet
To keep your laptop safe from heating
-buying a cooling pad is the best option
-you can also try keeping your laptop at power saver mode
-make sure that you do not use the laptop for day and night purpose
Computers & Internet Logo
Back of laptop very hot and bettery life short
Do you have a cooling pad for your laptop? because many laptops require it. Try using a cooling pad
Mar 24, 2014 | Sony VAIO Computers & Internet
laptop gos into screen saver mode then screen turns black and you have to shutoff with the power button and turn it back on to use it again tried turn off screen saver with no luck after about 3 min. the laptop becomes unresponsive
Unless you have already done so, check the power saver options in the control panel. You may have to tweek the timings to make sure power save options are not cutting in too early.
I don't know which windows operating system you are using but generally you will find the details in the Control Panel.
May 13, 2011 | Computers & Internet
shut down itself
Hi i'm Rain.
If your Laptop is over heating you may need to look into a stronger type of cooling system { Fan }
But for now lets set up your power Options settings
to try to keep your CPU cool.
In power options select Power Saver.
If you see the selection to keep the fan running select it also. save and exit.
Hopefully this will help to keep your system cool until you can service it.
Nov 25, 2009 | Compaq Presario Notebook
if i try to bring back from screen saver using touch pad the screen goes dark and i can only just see faintly the desktop. i have to switch off and restart machine to get it back
u must remove screen saver and go in screen saver property than go on the power there are some setting u must disable the power option and hdd sleep mode too be disable good luck enjoy vote for my comment
Aug 06, 2009 | Computers & Internet
343 people viewed this tip
David Payne
David Payne
