Tip & How-To about Cell Phones
How to send files from nokia mobiles quickly?
When you have to send files from gallery we select options and then decide which option . avoid it by just pressing the green call key and it would show the options. applicable for all nokia s60 3rd edition mobiles
Cell Phones Logo
i have alcatel z221 cant download pictures to computer
You can transfer pictures from your phone to your computer in 2 ways.
Bluetooth
1. Enable Bluetooth
- From idle mode, select Menu > Settings > Connections > Bluetooth.
- Press the OK Key to set Bluetooth to On.
2. Pair your phone to your Bluetooth enabled computer. If your phone does not have a built-in Bluetooth module, you can buy a Bluetooth dongle from your local electronics store.
- From idle mode, select Menu > Settings > Connections > Bluetooth > My devices.
- Press the OK Key to search for available Bluetooth devices.
- Highlight a device from the list and press the OK Key.
3. Select your desired file, and select Left Soft Key [Options] > Send > Via Bluetooth.
4. Select the target device from the device list, and press the OK Key to send.
Email
1. Select your desired file, and select Left Soft Key [Options] > Send > Via Message
2. Enter your email address. press the OK Key to send.
3. You can now download the file from your computer.
Aug 31, 2015 | Alcatel Cell Phones
how to delete ringtones off the samsung SCH-u340. From US Cellular.
  1. While in standby mode, press the OK button for Menu
  2. Select Multimedia / easyedge [This depends on your phone] (4)
  3. Select Gallery (2)
  4. Select Melody Gallery (2)
  5. Select Downloaded (2)
  6. Press the left key for 'Options'
  7. Select Erase [or Erase All]
  8. Highlight Yes, using the navigation keys
  9. Press the OK button
Jan 15, 2010 | Samsung SCH-u340 Cellular Phone
how do i change the ringtone for my incoming textmessages?
Press the Center Select Key Scroll to and Select Media Gallery Scroll to and Select Sounds If necessary, press Options Select Switch to Storage Device Select Phone Scroll to the desired file Press Options Scroll to and Select Assign as Ringtone
Jun 10, 2009 | Motorola Cell Phones
cant find sound folder on mini sd card to add tones from computer
This menu displays music files saved in your phone and microSD card. 1. From idle mode, press and hold the OK Key [OK] to unlock the keypad, press the Left Soft Key [Menu], the Directional Key to select “Media Gallery”, then slide out the QWERTY keyboard and press 1. My Sounds. 2. Scroll through the downloaded or saved sounds to select the sound and press the OK Key [PLAY] to listen to the highlighted sound. To erase the selected sound, press the Left Soft Key [Erase], then press the Right Soft Key [Yes]. 3. Press the Right Soft Key [Options] to choose from the following: • Send by Picture Message: To send a MMS message. • Send Online Album: To upload selected sound to sound online server. • Send by Bluetooth: To send selected sound to another Bluetooth device. • Set As: Assigns the selected sound for specific tasks (Ringtone, Contact ID, Alert Tone). • Rename: Rename the selected sound. • Lock/Unlock: Select to lock or unlock the selected sound. • Move: To move the sound to another location. • Erase All: To erase all the sound files in your phone. • File Info: Displays information about the selected sound. Since you can’t Send or Move a DRM file, the Send/Move options will not appear when working with these type of files. With microSD card inserted, you can browse all folders and sound files saved in the microSD card by searching the Back folder . indicates that current file is stored in the external memory. indicates that current file is stored in the phone memory. indicates that you have sub directory for the current folder.
Hope this helps, let me know if I can help you with anything else.
JimmyC
Jun 02, 2009 | UTStarcom Blitz Cell Phone
pictures
Its very easy.
Step 1:
Go to the picture browser on your cell phone. This can usually be easily found by pressing the camera button. When the camera loads up at the bottom of the screen, you should see one of the following options: "Browse," "Gallery," "Options," or "Tools." Press the button on your phone that corresponds with one of those (the top-left and top-right buttons on your phone perform whatever action the text on the bottom-left and bottom-right of the screen says). If there is only "Options" or "Tools," then a pop-up menu will open within which you will be able to select "Browse" or "Gallery."
Step 2:
Select the picture you want to send from your picture gallery. You should now be viewing just that picture.
Step 3:
Find the options for "Send," "Options," or "Tools" at the bottom of the screen. If there is "Send," push the button the corresponds with it. If there is only "Options" or "Tools," push the button for that, then select "Send" from the menu that comes up.
Step 4:
Enter the email address you want to send the picture to in the "To:" field. Use the numberpad on the phone to enter the letters. Any special symbols, including @, are most likely under the number 1 - just keep pressing it in succession until you get the symbol you want. If you make a mistake, the "Clear" button will backspace.
Step 5:
Press the "Send" button on your phone (the same one you would use to make a call). Your picture will be sent to the email address you specified.
Hope it helps.
Mar 18, 2008 | Motorola Mobility RAZR V3
117 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
