Tip & How-To about Washing Machines
Gas dryers
Have a problem with your dryer getting no heat? Do this when starting, listen for the clicking noise at the lower part of your dryer. That will be the ignitor making that sound to ignite the gas burner. If that ckicking sound is not heard you have a bad ignitor which can be replace
Washing Machines Logo
Clothes have to be dried several times before getting dry
The first thing to do is to remove the ryers exhaust venting tubes and clean them out thoroughly. Any lint build up will cause the moister sensor to keep the heat in check. It is a saftey device to prevent home fires from clothes dryers. Just on small clog will do this. If cleaned and still no heat listen for a clicking noise upon starting. If no click is heard the Spark ignitor is at fault. If it is clicking the moister sensor is at fault
Jun 26, 2010 | Maytag Neptune MDG5500AW Gas Dryer
dryer is not heating up to dry clothes
The spark ignitor maybe at fault. Listen for the clicking noise upon starting it up the first 30 seconds it runs. If not heard it is in need of a replacement
May 01, 2010 | Amana NED7200TW Electric Dryer
it just stopped heating
If you have a gas dryer the burner is ignited by a eletroniic ignitor. It will make a ckicking noise upon starting it when set in the heat mode. You should hear the click or clicking noise it makes within 30 seconds after starting the dryer. If no click is heard, replace the spark ignitor
Mar 30, 2010 | Dryers
DONT GET HOT
listen for the clicking noise the first 30 seconds upon starting your dryer. that clicking noise is to spark the ignitor for the burner to light it up. if not heard the ignotor is at fault and needs to be replaced
Feb 25, 2010 | Dryers
gas dryer wont heat
Feb 13, 2010 | Dryers
159 people viewed this tip
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
