Tip & How-To about Computers & Internet
Disable the Outlook Express Splash Screen You can make OutLook Express load quicker by disabling the splash screen: 1. Open RegEdit 2. Go to HKEY_CURRENT_USER\Software\Microsoft\OutLook Express 3. Add a string value "NoSplash" 4. Set the value data to 1 as a Dword value.
Computers & Internet Logo
hey . i installed a thingy called smiley center frm google and now i cant get rid of it. please help!!!
Hi, Please follow the below instructions inorder to uninstall the Smiley Central from your computer:- f you downloaded Smiley Central after March 11th:
1) From your computer's Start button, select "Settings", then select "Control Panel"
2) Double-click on the "Add/Remove Programs" icon
3) Select "My Web Search (Smiley Central)" or "My Total Search (Smiley Central)"
4) Click "Remove." Smiley Central and the toolbar have now been uninstalled.
If you downloaded Smiley Central prior to March 11th:
Depending on when you downloaded Smiley Central, you may be able to follow the steps above. If these do not work, please do the following:
Web-based email users:
To remove Smiley Central and your toolbar, you must do the following:
3) Select "My Web Search"**
(Click here to see a picture)
**Some toolbar versions may say "My Way Search" or "My Way Speedbar."
Outlook, Outlook Express and IncrediMail users:
To remove Smiley Central and the navigation bar from your email system, you must do the following:
3) Select "My Web Search (Outlook, Outlook Express, and IncrediMail)"**
4) Click "Remove." Smiley Central and the navigation bar have now been uninstalled from your email system. (Click here to see a picture)
**Some toolbar versions may say "My Web Search (Outlook, Outlook Express, and IncrediMail)" or "My Way Speedbar (Outlook, Outlook Express, and IncrediMail)."
To remove Smiley Central and the toolbar from both your email system AND your browser, you must do the following:
3) Select "My Web Search (Smiley Central)"**
4) Click "Remove." Smiley Central and the toolbar have now been uninstalled from your email system and your browser. (Click here to see a picture)
**Some toolbar versions may say "My Way Search (Smiley Central)" or "My Way Speedbar (Smiley Central)."
Incase you would like to disable Smiley Central from any particular application follow the below steps:-
Simply open Smiley Central and:
1) Click the "Preferences" button at the top of your Smiley Central window
2) Click the link under the "Enable/Disable" header
3) Check the box next to any application you wish to enable, uncheck the box to disable
4) Click "Save Changes"
Be sure to close any applications you have open, then open for your changes to take effect.
Thank you for your patience and best wishes for your effort.
Jan 08, 2011 | Facebook Social Network
outlook 2000 inbox
hello
In thsi case try to open outlook in safe mode
the command is
click on start
run
outlook /safe
if that works fine then there is some issue with the addin
then for thsi close outlook
click start
run
regedit
hkey local machine - software -microsoft-office - outlook - under outlook expand addin
then highligfht add in ione by one and on the right hand side modify the regisrt from any other value to 0 , do all thsi with all the addin and then try to open outlook
Mar 06, 2010 | Microsoft Outlook 2000 (543-00638) for PC
How to disable Outlook Express 6 Compact message prompt
Unfortunately, there is no easy way to disable this. The best you can do is delay the messages, or avoid them altogether. I have listed both methods below, and would suggest number 1 over number 2:
Method #1 - In Outlook Express, click on Tools>>Options>>Maintenance. Click on the Cleanup Now button, and then Compact. Doing this regularly will keep you from getting the messages.
Method #2 -
  • Open the registry (click on Start, Run, type Regedit and click Enter).
  • Browse to HKEY_CURRENT_USERIdentitiesyour identitySoftwareMicrosoftOutlook Express.0.
  • Look for the registry value titled Compact Check Count. This typically has a value of between 1 and 5, which means Outlook Express will check every 1 to 5 times to see whether you need to compact. Double click on the item, and set the number to 100, so you will only see the message every 100 times you open Outlook Express.
- I offer remote control assistance as well! Please send me a note at Info@LoganComputersER.com
Oct 19, 2009 | Microsoft Outlook Express
Cannot delete email from outbox in outlook express
Plz disable ur internet, close ur outlook without sending, then open again & if sending receiving then cancel immediately, now u can delete ur e-mail from outlook.
Mar 21, 2009 | Microsoft Outlook Express
change hotsync
Changing back to Palm Desktop Software from Outlook with Tungsten E 1 Place the Installation CD that came along with your handheld onto your cd-rom. Wait for it to load after which you’ll see a splash screen with different menus. Note: If the cd does not automatically load, double click on my computer then click on the cd-rom drive icon and finally click on the first icon (looks like a cd) labeled ‘autorun’ 2. Select ‘Install Microsoft Outlook Conduits’ 3. Click on ‘Install’ 4. Click on ‘Yes’ 5. Click on ‘Yes” 6. Click on ‘Ok’ 7. Click on ‘Back’ 8. Click on ‘Exit’
Sep 11, 2005 | Palm Tungsten E Handheld
160 people viewed this tip
David Payne
David Payne
