Tip & How-To about Microsoft Windows XP Professional SP2
Enable WZC (Wireless Zero Configuration) and connect to wireless network on Windows XP
Windows XP has built in wireless utility which can be used to connect to the wireless network. Though, you can still use the wireless utility software that came with the wireless adapter. Please perform the following steps on your XP wireless computer to enable WZC (Wireless Zero Configuration):
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply.
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab.
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
7. Highlight thee SSID from the list that you want to connect to.
8. Type the security Key here and click on the 'Connect' button.
9. You should have successfully established a wireless network connection.
These steps will help enable wireless zero configuration on your XP wireless computer and you can connect to your wireless network using it.
Microsoft Windows XP Professional SP2 Logo
how do i switch to windows wireless configuration utility
If you are using Windows XP, Vista, or Server 2003, you have an option in how your wireless network card is managed. You can choose to use your manufacturer's Configuration Utility software, or you can use the configuration software built in to Windows.
If you wish to switch between your manufacturer's Wireless Configuration Utility and the Windows Wireless Zero Configuration service:
1. Go to Network Connections (from the left panel of My Network Places)
2. Right click on the icon for your wireless network card, and choose Properties
3. In the Properties dialog box, choose the middle "Wireless Networks" tab
4. Check or Uncheck the box on the top that enables Windows management of wireless connections
5. Click OK
A reboot is recommended. If you are using any form of WPA or 802.1X security, you will likely need to reboot the computer before you will be able to access your wireless Access Point -- even if it is configured correctly.
Even when both the manufacturer's software and the Wireless Zero Configuration services are running, the Configuration Utility should detect when Windows is not managing the connection and give you access to its own configuration options.
Likewise, Windows should detect when it is not enabled to control the wireless network configuration, and disable access to the Windows configuration options.
Advanced Troubleshooting:
Before proceeding, be sure to download a local copy of the manufacturer's software and driver should you find yourself with a disabled network card and a need to reinstall the software.
A. If you suspect that Windows is interfering with your wireless network, regardless of the setting, you can disable the underlying service. If the Wireless Zero Configuration service is disabled, Windows will not be able to manage the wireless network -- regardless of any setting. To permanently disable the Wireless Zero Configuration service, click Start, Run, and input services.msc and press Enter. In the Services window that follows, find the Wireless Zero Configuration service, double-click it, and change the startup option to Disabled. Reboot. If you still have issues, uninstall and reinstall your manufacturer's software now that the Wireless Zero Configuration Service is disabled. It should set itself up correctly now.
B. If the Manufacturer's configuration software is interfering with Windows' management of your wireless card, consider uninstalling your Manufacturer's software. Windows only needs the driver in order to communicate with your card and manage the wireless network. Everything else is optional. Remove the software from Add/Remove programs. The uninstall program might give you an option to uninstall everything except for the driver, or it might have separate Add/Remove Program entries for the utility. If it does not, then reinstall the software using the local copy you downloaded and look for an option that installs only the driver.
Mar 12, 2013 | Acer Aspire 5536-5224 Notebook
I Installed the software for the Zonet ZEW2508 on my laptop with windows xp home.. Now what? (I have an operating wireless router already)
Ignore the software and use the built-in wireless utility that comes with Windows to configure your network. There should be a small icon by the clock that looks like a radio antenna with waves, right-click it and select to 'View Available Wireless Networks'. The rest is self-explanatory.
If the Windows utility states that it is not managing your wireless networks, you'll need to disable the Zonet utility first. If you need help with that, let me know.
Good Luck!
-Kevin
Jan 04, 2011 | Zonet ZEW2508 54Mbps WirelessG Usb Adapter
Can't use my adapter...
Does the EUB-362/362EXT/862 work with Windows Vista? No, the EUB-362/362EXT/862 Client Utility was written for use with Windows 2000/XP. Microsoft Windows Vista users must use the "Connect to a Network" utility in Windows Vista.
Is the EUB-362/362EXT/862 Client Utility software supported on Microsoft Windows Vista? No, the EUB-362/362EXT/862 Client Utility was written for use with Windows 2000/XP. Microsoft Windows Vista users must use the "Connect to a Network" utility in Windows Vista.
What is your OS?
Dec 10, 2010 | EnGenius EUB-362 (EUB362 EXT) Wireless...
Cant find the wireless card utility to search for wireless networks
What is the operating system on your computer ?
If it is windows XP then you can enable the wireless zero configuration and use windows wireless connection manager.
For windows Vista and 7 the wireless utility is built in and you can use the Windoes.
Click Here for more information about the routers and network
Jun 16, 2010 | Computers & Internet
The device manager shows that the D-link Airplus G DWL-G510 is working properly. I have XP - SP3. But when I try to set up the network, it says that media not connected and ti=o check that the wireless switch is on.
Are you trying to connect to the wireless network ?
You are using windows XP computer. and you have D-link adapter.
In case of windows XP computer there is built in utility to connect to the wireless network. and also you have Dlink utility to connect to the wireless network.
It will be better to use the Windows utility to connect to the wireless network.
Search for the wireless network and you will see your wireless network. I believe you have the wireless router.
Apr 27, 2010 | D-Link AirPlus G DWL-G510 802.11g/b...
719 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
