Tip & How-To about Televison & Video
Lost Remote Control? Here's a way to help.
So you have lost, or, your remote doesn't work? You can't "Do anything" without it.... Right.... NO Wrong... ALL TV sets have a number, usually about 5 - 6, "Buttons" on the side, front, somewhere. usually close to the "Power ON" switch. Now these "Buttons" will perform nearly all, if not all, of the main functions of your "Remote" They WILL be marked, MENU, +, -, <, >, & OK or ENTER. Now you simply have to depress each button to access the "Functions" you want. One button WILL control the "Function" say Channel, and the <, >, will Go UP & DOWN. This is the same for everything. So one button will make it, say go UP, another will make it,say, go DOWN. Repeated presses on the "Function" Button will scroll through the "Functions" IE: Channel, Brightness/Contrast, Selecting Inputs, once "Selected" another "Button" will move the "Selector" through to the Bottom & another will scroll it back Up, sometimes the ONE button will simply continuously scroll "right around" Of course have a look in your manual... you know that paper thing you shoved away in the cupboard... This will explain it all. ALL TV's and devices that use a "Remote" are ALWAYS able to "Control" the MAIN functions of the unit,via keys on the actual unit itself. So don't despair, just spend a bit of time learning your "Buttons" that way even if the "Remote" does go walkabout, or the batteries go flat, or it just stops working.. well now you can still have complete control.. the only draw back is you will have to get put of your seat to do it. A small price to pay?
Televison & Video Logo
RCA flatscreen remote doesn't work
\its most likely the ir sensor which has the issue. I will need the model number of your set to help you further on the issue. You can reply to this same post for further assistance if needed.
Jan 01, 2013 | Televison & Video
need codes for universal remote for tv
Buy generic remote, after you verify that your make and model are supported first. If you buy the remote at a local "superstore", verify the return policy if it doesn't work. Simple models are very inexpensive.
Alternative is some phones have IR ports and you may find a program to control your TV with it. Far fetched, but you might have the right combo.
Good luck
Oct 28, 2011 | Televison & Video
i want to set my samsung home teather remote to my vizio tv the remote is a ah59-02291a
hi,
Need the model number of the samsung Home home theatre system to give to correct code.
OK
Aug 13, 2011 | Televison & Video
lost my remote and tv is hung on zoom...anyway i can get off zoom without the remote?
Yes there is a way around zooming in and out without the television remote control. The cable box/satellite tv receiver also has an option to zoom in and out on it. BUT it usually only works when you have the hd box/receiver AND the television has to be on the right input in order to receive hd (component input or hdmi input). PLUS the cable box/satellite receiver should be set on the 1080i resolution (or 720p depending upon the resolution the television can accept). Then you can find the button on the remote that says #hd zoom (yes the # sign is on the button) or the button may be format or aspect.
Feb 08, 2011 | Philips 32PFL3504D 32 in. LCD TV
where can I get a remote for my symphonic 27in mts/sap tv my original one was lost
www.replacementremotes.com then just enter the model number of your set. They will have the origional for your set so all the functions will work without programing anything.
Mar 19, 2008 | Televison & Video
207 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
