Tip & How-To about Computers & Internet
How to Configure Windows XP to send and receive Fax?
If you are using windows XP, you can use sending and receiving option for fax service built into windows XP. You can enjoy free facilities of fax from your computer, because buying a dedicated fax machine for home or small office may not be a feasible option. Using windows XP based fax services; you can read, save, forward, delete the fax messages. By default fax service is not installed in your windows XP, but if you have windows XP CD, you can install fax feature using Add or Remove Program option.
Follow the gives steps to install fax components:
  • To install this feature, you will need to be logged into your computer with administrative rights.
  • Make sure, you have installed modem driver on your computer before running fax components setup.
  • Now click on Start button and go to System Control Panel then double click on Add or Remove Program.
  • Select the Fax services check box under Add or Remove Windows components.
  • Now click Next to finish the fax installation wizard and close it.
After the fax components installed, now configure the fax setting before using it.
  • First click on Start button, go to All Programs> Accessories> Communications then click on Fax Console.
  • Now in fax configuration wizard, type the fax cover page information then click on Next.
  • Select the suitable modem for fax and also enable others send and receive options.
  • Now type the TSID (Transmitting Subscriber Identification) and click Next then type here CSID (Called Subscriber Identification) and again Next.
  • At the end select the printer to be automatically printing the fax and click to finish.
Computers & Internet Logo
i have hp laserjet 3050 guide me how to connent fax and how to send fax
Sending and receiving faxes by using a computer
This section contains basic instructions for sending faxes by using the software that came with the allin-one. All other software-related topics are covered in the software Help, which can be opened from the software-program Help menu.
NOTE The HP fax software and HP ToolboxFX are not supported for Windows 98 or Windows Me. The HP ToolboxFX software is not supported for Macintosh.
NOTE Receiving faxes by using a computer is not supported for Macintosh.
You can fax electronic documents from your computer if you meet the following requirements:
? The all-in-one is connected directly to your computer or connected to your computer over a TCP/
IP network.
? The all-in-one software is installed on your computer.
? You are using Microsoft Windows 2000 or XP or Mac OS X V10.3 or Mac OS X V10.4.
To send a fax from the software (Windows 2000 or XP)
The procedure to send a fax varies according to your specifications. The most typical steps follow.
1. Click Start, click Programs (or All Programs in Windows XP), and then click Hewlett-Packard.
2. Click HP LaserJet all-in-one, and then click Send fax. The fax software appears.
3. Enter the fax number of one or more recipients.
4. Load the document in the automatic document feeder (ADF) input tray.
5. Include a cover page. (This step is optional.)
6. Click Send Now.
NOTE You can also send a fax from HP ToolboxFX by navigating to the Fax Tasks section
and clicking the Fax Send button.
Jul 22, 2011 | HP LaserJet 3050 All-In-One Printer
hi i don't have problems the only think is how i send fax whit the print faced up or faced down?
http://wiki.answers.com/Q/How_do_you_enter_the_document_in_a_fax_face_up_or_face_down
to make it clear ..the sending by scanning is only available in a all in one printer with fax options ..and the other classic faxes are always feeding the face up ..
read the topic I linked here cause it is explained in detail ..and please don;t forget to rate the answer if it is helpful ..Thank you ..
Jul 11, 2011 | Office Equipment & Supplies
unable to send and receive faxes
You need fax software or enable XP fax services. XP Fax services is enabled through the add/remove programs in the control panel. Open add/remove programs, and click on add windows services
Apr 15, 2009 | Arris Touchstone 450a (CM450) Modem
I would like to use my epson stylus cx7800 to receive and send fax's. Can this be done. Please explain and instruct. Thanks. lstrat@telusplanet.net
If you are running Windows, and have a modem, you can use the Windows Fax Services which are built in.
You may not have it installed, as it's an optional component. Go to Control Pane/Add Remove programs. Select Windows Components on the left hand side. If Fax services is not checked, do so, and press OK. You may need your original Windows install CD to complete the task.
If you still need help with this, please respond to this message. If I have solved your problem, I would appreciate you rating this as "solved".
Good Luck
airoff
Jul 21, 2008 | Computers & Internet
162 people viewed this tip
David Payne
David Payne
