Tip & How-To about Cameras
How to avoid fungus on Digital Camera Lens?
The dreaded fungus is something that bothers every photographer. I have suffered from it before, and every coming rain gives me constant worries of possibilities of fungus growing somewhere inside my lenses. I am more vulnerable to fungus than most people because I don't think much about taking out the camera to get some good shots even if it has been raining a bit, and have often got plenty of rain drops on the camera and the lens therefore.
Where does fungus comefrom?
  • Fungus spores are everywhere and germinate under suitable environmental conditions:
  • Relative humidity of at least 70% (more than 3 days)
  • No or little airflow
  • Darkness
  • Nutrients (textile lint, traces of grease, varnish, dust and dirt)
  • Temperatures between 10 and 35°C
How can fungus be avoided?
  1. Silica Gel. This seems to be the easiest and common way to avoid fungus, but I haven't had much success with it either.
  2. . Store the lenses in an airtight container. Again, you may need to put a few Silica Gels in the container. Putting too many of Silica Gel is known to dry out the lubricants in the lens, so you need to use your discretion with quantity of the Silica Gel.
  3. . A popular idea is to install a low wattage tungsten bulb in the closet where you keep the lens. This will keep the place warm and dry, preventing the fungus. This is known to work.
  4. . Store the lens in transparent container. Fungus is known to fear light and love darkness. Also make sure that the lenses are not stored in leather bags, as leather can easily attract fungus.
  5. And finally, of course, the best way to prevent fungus is to get out and shoot more often.
  6. After the work is done, immediately clean the instruments. If possible, you can use a fan or blower to facilitate evaporation of surface moisture.
Cameras Logo
lcd screen display
why it would fit mengamabil photograph blank screen
Jul 12, 2013 | Sony Cyber-Shot DSC-P93 Digital Camera
smudge showing up in view finder and on photo PowerShot SX210
Is there a visible smudge on the front element of the lens? If so, you can use a LensPen or cleaning cloth from the photo department of your favorite store.
There is the possibility that there is fungus growing inside the lens elements of the camera. Humidity can allow this to happen over time with camera lenses as well.
If you have fungus inside the lens, you may need to check with a repair shop... buying a new camera may be in your future.
Jun 19, 2012 | Canon Slim Camera Case(11160306581) for...
sigma 500mm lens need to remove funges from inside lens,but funges not showing on photographs is it possible to strip
That is a manufacturer repair. While you may be able to remove the fungus, the fungus may have etched the coating on the lens and still show . The best way to fix that is replace those lens elements that are effected.
Oct 30, 2009 | Cameras
fungus inside lens
if it's mild then it won't have any appreciable effect on your photographs, so leave it until it's worse. The fungus can be slowed or killed by sunlight or by exposing the lens element to ultra violet light.
If it's really bad then you have to decide whether it's worth a professional strip down and clean. You'd have realistic two choices: to remove the fungus and replace all lubricants and canada balsam lens cement with modern antifungal equivalents but leave the damaged lens coatings as they are or to do the same and also have affected lens groups replaced with new ones or have the old ones re-coated. The first option is expensive, the second option is very expensive.
Jul 31, 2009 | Mamiya Macro 140mm f/4.5 L-A for RZ67
I have a Minolta Rokkor-x 200mm telephoto lens with fungus
Lens fungus is really common and it's not cost effective to repair. Even if the fungus is removed then the multicoatings are permanently damaged.
The good news is that until the fungus becomes pretty severe the image quality doesn't suffer much as most photos use the lens stopped down to some extent and this means that if the centre of the lens is clear then there's nothing to block the light paths.
Unfortunately it does tend to spread, so keep affected lenses in a separate camera bag to the rest and if you can afford to do so then throw them away and replace your camera bag as it will be loaded with microscopic spores waiting to attack more lenses. Making sure that your camera and lenses are completely dry and free of condensation before storing them until next used will prevent reoccurence.
Jun 16, 2009 | Cameras
506 people viewed this tip
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
