Tip & How-To about Cell Phones
How to Reset a Blackberry
There are three main types of Reset that apply to the Blackberry. These are listed in order below. Instructions for Blackberry Pearl are slightly different - see bottom section of the Tip.
1) Soft Reset - simply press the ALT+RIGHT SHIFT(CAP)+DELETE keys.
This reset stops all applications that are running on the Blackberry and will help if you are having problems connecting the device to computer. This reset will not erase any information from your device.
2) Double Soft Reset - this reset is almost equivalent to a full hard reset. First perform a Soft Reset as outlined in Step 1.
As soon as the screen is no longer black - repeat the steps once again exactly as before.
This takes you to another screen showing an hour glass. Allow the device to reset. This helps if the device has suffered a more serious error. Be aware you may loose some information from your device. A backup is advised prior to proceeding if at all possible.
3) Hard Reset - this is the full blown reset and will fully reset the device to help resolve critical errors with software or hardware. Again back up important information before proceeding if possible.
Note: For RIM models 850, 857, 950, or 957, you must insert the end of a paperclip or similar blunt object into a small recessed hole on the back of the unit and depress the switch inside. The device will reboot and be hard reset.
Other Models: With the device turned on - remove the battery for 30 seconds or more. Now replace the battery. The device will reboot and be hard reset.
Blackberry Pearl: To reset to factory defaults enter 'Options' from the main menu. Scroll to Security Options and press the trackball. Choose 'General Settings'.
Press the left soft key, then scroll to "Wipe Handheld" with the trackball and press the trackball. To initiate the factory reset, your phones security code may be required in order for the process to complete. Your phone will now be restored to its original settings on leaving the factory.
A hard reset can be achieved with the Pearl in the same way as outlined at Step 3 by removing the battery.
Be aware that resets such as these may erase data, such as contacts, ring tones, pictures, text messages and stored Internet files and emails. Make sure to back up important information beforehand if at all possible. You can obtain software to back up the device to your computer directly from Blackberry right here.
Hope this Tip helps. If so please do leave a vote for the solution.
Thanks.
Cell Phones Logo
Blackberry Cure 8310 app error 205 rest
Be aware that resets such as these may erase data, such as contacts, ring tones, pictures, text messages and stored Internet files and emails. Make sure to back up important information beforehand if at all possible. You can obtain software to back up the device to your computer directly from Blackberry Below.
software112.com/products/blackberry-desktop-software.html
Thanks.
Jun 16, 2011 | RIM Blackberry 8310 8320 8330 Curve 8100...
I took out the battery and place it back in, now there's a lil black clock showing off an on then disappears. When i flip the phone open app ERROR 523 and Reset shows up on the screen
Be aware that resets such as these may erase data, such as contacts, ring tones, pictures, text messages and stored Internet files and emails. Make sure to back up important information before hand if at all possible. You can obtain software to back up the device to your computer directly from Blackberry Below.
Thanks.
May 23, 2011 | RIM BlackBerry Pearl Flip 8220 Cellular...
hvb error on blackberry bold 2 ...not able to re boot
Hi, you can try and reset the phone with the following instructions below. worked for me.
Thanks.
Jan 25, 2011 | Cell Phones
Hi my name is dean I have a bberry curve 8520 and want to know how to fix or reset my phone.it shows reload software error:552
Thanks.
Jan 21, 2011 | RIM BlackBerry Curve 8520 Smartphone
app 523 error blackberry pearl 8220
Hi, You can reset the phone to clear the error
Thanks.
Jan 07, 2011 | RIM BlackBerry Pearl Flip 8220 Cellular...
442 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
