Tip & How-To about Computers & Internet
How to reset Nintendo DS Lite.
Remove the cover for the battery compartment. At the back of the DS Lite, the cover has a small screw holding it in place. You will need a Phillips size 0 screwdriver to remove it.
Take out the DS Lite's battery pack. There is a tab at the top of the battery pack. Insert your fingernail or the end of the screwdriver carefully into the edge of this tab and pop out the pack.
Keep the battery pack out of the unit for at least 10 seconds. If you keep the battery pack out for too short of a time, it will not cause a reset in the unit.
Put the battery pack back. Just line it up in the compartment and push it back into place.
Replace the cover. Replace with the screw.
Turn on the DS Lite. If the unit has properly reset, a screen will come up that reads "Before you begin, you must adjust system settings." You can now enter all new settings and information on your DS Lite. If you do not get the system settings screen, you did not keep the battery pack out long enough. Repeat the steps and leave your battery pack out for a longer period of time.
Computers & Internet Logo
how to reset your nintendo DS
Hi. Here's the procedure on how to reset the console. Take note that if you are going to do this procedure this will erase all of the data saved on the system and restore the unit to its original factory settings.
Remove the cover for the battery compartment. The compartment is located on the back of the DS Lite unit, and the cover has a small screw holding it in place. You will need a Phillips size 0 screwdriver to remove it.
  • 2 Take out the DS Lite's battery pack. There is a tab at the top of the battery pack. Insert your fingernail or the end of the screwdriver carefully into the edge of this tab and pop out the pack.
  • 3 Keep the battery pack out of the unit for at least 10 seconds. If you keep the battery pack out for too short of a time, it will not reset the unit.
  • 4 Put the battery pack back into the unit. Just line it up in the compartment and push it back into place.
  • 5 Replace the cover. Secure the cover back into place with the screw.
  • 6 Turn on the DS Lite. If the unit has properly reset, a screen will come up that reads "Before you begin, you must adjust system settings." You can now enter all-new settings and information on your DS Lite. If you do not get the system settings screen, you did not keep the battery pack out long enough. Repeat the steps and leave your battery pack out for a longer period of time.
  • Sep 12, 2010 | Nintendo DS Console
    DS Lite not turning on? Read this tip to find out how to fix it!
    Thank you for a well explained fix to this problem Just one question...I have rarely used a soldering arm and I am worried about causing heat damage etc to the board. I have read about using a "circuit sealer pen" or similar as an alternative? Is this a safer option?
    Aug 30, 2010 | Nintendo DS Lite Console
    Nintendo DS Lite Battery needs to be changed. How can I take off cover?
    All you need is a small phillips screwdrive. Use this to undo the small screw and then the cover will come off. The battery is also very easy to take out, just be careful not to damage the pins inside when you remove the battery.
    Hope this helps and thanks for using FixYa
    Aug 20, 2010 | Nintendo DS Lite
    i want ot sell ds i want to no how to wipe the whole thing
    Remove the cover for the battery compartment. The compartment is located on the back of the DS Lite unit and the cover has a small screw holding it in place. You will need a Phillips size 0 screwdriver to remove it.
    http://vodpod.com/watch/2607802-nintendo-ds-lite-reset
    Mar 16, 2010 | Nintendo DS Lite Console
    how do you restart nintendogs
    No No No! Bad Silver! Before You See The Nintendo Sign (It may be after) Press and Hold A +B + X + Y + L Trigger + R Trigger and that's all. Taking Apart Your DS gives you a 99% Chance of epic fail. -_-
    Feb 12, 2010 | Nintendo DS Lite
    334 people viewed this tip
    David Payne
    David Payne
