Tip & How-To about Computers & Internet
How to check the version of windows 98/Xp/vista/windows7/server2000/server2003/server2008
Step 1: Go to start-> run and type winver
step 2: Done! you will get a window like this.There you can see all the details!
Computers & Internet Logo
why can't I install adobe photoshop cs3 on to sr1619uk windows XP compaq presario? I have over 2gb and athlon 64 + radeon xpress 200 graphics.
Please check if your Windows XP is service pack 2 or above. As CS3 wont work on XP service pack 1.
To check for service pack, Click on Start, Click Run, Type "Winver", Click OK.
Regards,
Shrey
Jun 06, 2011 | Computers & Internet
my computer does not have sound unless it's plugged in
First check if the Vista Service Pack 1 or 2 is installed in the Computer and what is the version of the BIOS installed in the Computer.
To check the information about the Service Pack installed in the Computer:
Click on Start, type WINVER in the Search area and then press the Enter key.
Or
Please goto Start Menu, select 'All programs', select 'Accessories' to access 'Run' option and enter 'WINVER' and check whether Windows Vista SP1 or 2 is installed in the Computer.
To check the version of the BIOS installed in the Computer:
Click on Start, type MSINFO32 in the Search area and then press the Enter key.
In the System Information window check the BIOS version.
If the installed BIOS version is not R0231Q0 or higher then install the BIOS update in the Computer from this Link.
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNCR190E&upd_id=3745&os_id=28
This is a known issue with a VGN-CR series Computer when Audio may not work properly after installing Microsoft Windows Vista Service Pack 1 (SP1).
Installing the BIOS update should resolve the issue.
If the issue still persists after installing the BIOS update then you may try installing the Audio Driver from this Link.
NOTE: Please first go for the BIOS update as it is a well known issue with a VGN-CR series Computers.
If the issue still persists, follow the steps as mentioned on this Link to resolve the issue.
Good Luck!!!!!!!!!!!!!
Nov 14, 2009 | Sony VAIO VGN-CR190E/L Laptop PC Notebook
no sound coming on my laptop VGN-CR220E
Please first check whether the Vista Service Pack 1 or 2 is installed in the Computer and what is the version of the BIOS installed in the Computer.
To check the information about the Service Pack installed:
Or
If the installed BIOS version is not R1121Q0 or higher then install the BIOS update in the Computer from this Link.
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNCR220E&upd_id=3618&os_id=28
Oct 26, 2009 | Sony VAIO PCG-K23 Notebook
Unable to access my 4 GB Transcend pen drive with Windows Vista Home Premium Edition. Able to access it with Windows XP successfully but always prompting "Unable t find driver" when tried with Vista
Here are the 3 possible solutions to this problem,
SOLUTION 1 :-
Make sure the you have the Service Pack 1 installed for you vista computer.
You can find it out by opening the run command and type "winver" (without quotes) there. If it's not showing SP1 please update Windows Vista to Service Pack 1 which includes the update to fix this problem as this was the problem when vista was launched but fixed with SP1.
If updating vista does not resolve the issue try the solution provided below:
SOLUTION 2 :-
Manually locate the driver within the Vista operating system.
Microsoft Windows Vista may not find any driver for the device that is plugged in the USB port because the usbstor.inf (for MSC device) or wpdmtp.inf (for MTP enabled devices) is not present inside the C:\Windows\INF folder.
To resolve this issue, you must copy the driver files to the C:\Windows\INF folder.
Browse to the following folder:
1. C:\Windows\System32\DriverStore\FileRepository.
2. Look for the folder that starts with usbstor.inf_.
3. Copy all the files inside this folder to C:\Windows\INF.
4. Disconnect and reconnect the device.
If the problem still persists, try this Solution:
SOLUTION 3 :-
Clear hidden devices and make changes to the Registry
First backup your registry by  following these steps,
1. Click Start
2. Type regedit on the start search field, then press Enter.
3. Click File then select Export.
4. Under Export Range select All.
5. Type in the desired name to be saved.
STEP 2 - Remove Hidden Devices
1. Click Start..
2. Type cmd on the start search field , then press Enter.
2. Type set DEVMGR_SHOW_DETAILS=1 and press Enter.
3. Type set DEVMGR_SHOW_NONPRESENT_DEVICES=1 and press Enter.
4. Type start devmgmt.msc and press Enter.
5. Device Manager window will appear
5. Click View, then select Show hidden devices.
6. Click + to expand Imaging devices, Unknown devices, and USB devices.
7. Verify if there are any devices and unknown devices (including grayed out devices). Uninstall.
STEP 3 - Remove all oem*.inf files
1. Click Start.
2. Type cmd on the start search field and press Enter.
3. In the command line, type in the following commands and press Enter after each command:
  cd \windows\inf
  ren infcache.1 *.old
  ren oem*.inf *.old
  del C:\windows\setupapi.log
  exit
STEP 4 - Remove entries under HKEY_LOCAL_MACHINE\System\CurrentControlSet\Enum\USB
Remember,if you have a USB keyboard or mouse, do not remove the VID entry for these devices, otherwise, Windows may not restart correctly.
1. Click Start
3. Click on the "+" symbol beside HKEY_LOCAL_MACHINE
4. Navigate to \System\CurrentControlSet\Enum\USB.
5. Highlight and delete all the VID_xxxx entries.
Please note that if you have a USB keyboard or mouse, do not remove the VID entry for these devices, otherwise, Windows may not restart correctly.
After this turn off your PC completely then with the PC turned off, plug the USB flash drive to a USB port and then turn on the PC.
Now, a New Hardware Detected balloon will appear and the USB drivers will load automatically.
Please let me know if the problem persists.
Nov 18, 2008 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
523 people viewed this tip
David Payne
David Payne
