Tip & How-To about Office Equipment & Supplies
Cleaning the waste ink pad on most printers.
Assuming that you have already removed the Waste ink pad from your printer. Place it in hot running water and i mean lots of water. when you think enough of the ink has been cleaned, start squeezing the waste ink pad in the running water do this until no more ink comes out and the pad is White in color. Replace it your printer and you are good to go.
ip2772 error 5100
You can follow the given steps:
  • Open the top of the printer.
  • Locate the waste ink absorber pad on the right side of the inside of the printer. Grasp the pad and pull up to remove.
  • Clean the waste ink absorber compartment with a tissue or cloth.
  • Take the waste ink absorber pad to a sink. Run warm water over the pad and wring it out to clean it. Wring the excess water out when done cleaning.
  • Set the waste ink absorber pad on a dry paper towel or clean cloth to dry.
  • When the pad is dry, place it back into it's compartment in the printer.
  • Close the top of the printer.
  • Press and hold the "Resume" button on the printer. Press and hold the "Power" button while holding down "Resume."
  • Release the "Resume" button. Press "Resume" twice. The indicator light will turn amber followed by green.
  • Release the "Power" button.
  • Press the "Resume" button four times.
  • Press the "Power" button. The error code is now reset.
**If you need any technical help on printer then you can reach at http://www.vtechsquad.com/printer-support/
Mar 14, 2013 | Canon PIXMA MP160 All-In-One InkJet...
How can I change the foam pad that absorbes ink? What part is that called?
Hello
Its better to just remove them clean them up and replace it in the printer, because usually some printers require a reset code to re-set the waste ink counter. If the counter is not re-set there will come a time when then printer will refuse to print.
Here is how to clean your waste ink absorber;
Open the printer and locate the waste ink absorber near the ink cartridge.
Remove the absorber pad and hold it in cold water while squeezing the ink out. It would be wise to wear gloves while doing this, because the ink in the pad will leave stains.
Use paper towels to dry the waste ink absorber pad. Let it dry completely before installing it back in the printer.
Reinstall the ink pad into the printer and run a test page to make sure it works.
Apr 20, 2011 | Epson Stylus Photo R300 InkJet Printer
Message says :"waste ink absorber
Clean it out, its a pad underneath the print head, you've not said which model printer you have so I suggest you go to the manufacturers web site, follow links for support and see if there's a FAQ frequently asked questions page with your issue mentioned.
Apr 18, 2011 | Office Equipment & Supplies
i have got error 5100 what does this mean
Hello
Error code 5100 describes a physical problem either with a paper jam or an incorrectly seated ink tank. Resolving the error is a quick process that only requires a few standard troubleshooting procedures.
Press down and hold the "On/Off" button, which is located on the printer's operator panel, for one second. Wait 15 seconds and then tap the button again. Attempt to print or scan a document.
Check the paper feed tray on the front end of the Canon printer to see if there is any paper visibly stuck inside the printer. Open the printer cover by gripping the front edge of the printer and lifting upwards.
Grab the edge of the jammed paper and gently pull towards you to remove the paper from the paper feeder. Unplug the Canon's power cable and USB cable, and then turn the printer around.
Pull off the rear plastic cover tab and check if there is any visible paper jam. Grab the edge of the paper and gently pull toward you until the paper is removed.
Push the rear plastic cover tab back into place, and reconnect the power cable and USB cable. Attempt to print or scan another document to see if the error is resolved.
Lift open the printer's cover again and wait for the ink carriage to slide into view. Press the "Push" button on the front of the first ink tank. Pull the tank out and then push it back into place to ensure it is properly seated.
Repeat the process with the other three ink tanks, and then close the printer's cover. Power the printer off and then back on again.
But in some other canon printers,Error code 5100 indicates that the waste ink absorber has reached maximum capacity. The Canon i860 printer uses the waste ink absorber to keep ink residue off the printer heads and internal printer components. To resolve this error code, the waste ink absorber must be cleaned out and the error code message needs to be reset.
Nov 13, 2010 | Canon Office Equipment & Supplies
spillbläck full? What to do
It means that the pad that absorbs the ink when the heads are cleaned is full and if you use it more it will spill the ink over your desk. The official way to deal with that is to take the printer to a dealer and they will clean the absorbing pad and reset the warning.
You can do both yourself:
1 - to clean the ink pad: remove the cartridges and unplug the combo - the carousel should remain in the middle, leaving the pad in the right side visible; take the printer to your sink and pour water over it thru a pipe (try not to splash it everywhere) until the pad becomes white and the water that flows out colourless; allow it to dry thoroughly (at least 2 days in a hot environment).
2 - Reset the Waste Ink Volume Counter
1) Press Menu + Copy + # to enter SERVICE MODE.
2) Select TEST MODE.
3) Select 8 - PRINTER TEST in TEST MODE.
4) Select 3 - EEPROM CLEAR.
5) Select 0 - INK COUNT.
6) Press the OK key.
7) Press the Stop/Reset key (returning to the state of 3) and then press the ON/OFF key.
May 01, 2010 | Canon SmartBase MP360 All-In-One InkJet...
205 people viewed this tip
jasbo
jasbo
