Tip & How-To about Computers & Internet
TURN ON YOUR PC IN JUST 10seconds
Click on the start button then press R it will take u to Run well go to run
n type Regedit
press enter
this will open Registery Editor
now look for the key
HKEY_LOACAL_MECHINE\SYSTEM\CurrentControlSet\Contr ol\ContentIndex
now there find the Key Called
"Startup Delay"
Double Click On It
Now where its Base
Click Decimal
Now its Default Value Is 4800000 (75300:hexadecimal)
Change The Value To 40000
here u go u have done it
now close the Registery Editor and Restart Your Computer
You'll See The Result
USE @ your own risk
01010110 G.I.G hacker 0101010
www.gighacker.blogspot.com
Computers & Internet Logo
Error
U can clean ur all registry errors from reginout
Jul 26, 2010 | Dell Dimension 2400 PC Desktop
How do I get into the registery of an Acer aspire 5515 registery with Windows Vista home basic operating system to clean out Security Tool inputs?
Click on Start->Run or press the windows button and r simultaneously in key board. Type "Regedit" without double quotes. Press Enter. Take backup of registry before editing it and don't play with it if you are not confident of what you are doing. Your system may not boot if you do something wrong to registry.
May 20, 2010 | Computers & Internet
runs all the time very slow shutdown
When you shutdown your Windows XP computer, it may take more time to complete the shutdown process. Slow shutdowns are caused by a number of factors. One of the common cause is the Clear Pagefile at Shutdown option enabled.
Some points to improve the shutdown times:
Follow these steps to open registry editor.
  1. Click on start and the click on run
  2. In run dialog box type regedit
  3. Either press enter or click Ok button on the run dialog
Start Registry Editor and navigate to the following key:
[HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management]
Set ClearPageFileAtShutdown value to 0.
Feb 22, 2010 | Computers & Internet
183 people viewed this tip
David Payne
David Payne
