Tip & How-To about Computers & Internet
Use Your Pen Drive as Ram 1) Connect your pen drive to your PC [pen drive should be at least 1 GB or if you having 4 GB then its better] 2) Allow PC what he is supposed to do,let system to detect pen drive. 3) After your PC finished with its detection work,you have to do some little 4) Right click on the My Computer and select the properties 5) Goto advanced and then performance setting then advanced then 6) Select pen drive and click on custom size " Check the value of space available " 7) Enter the same in the Initial and the Max columns " You just used the memory of the PenDrive as a Virtual Memory " 8) Now restart your pc and enjoy your fast and super system 010100101 G.I.G hacker 010100101 www.gighacker.blogspot.com
Computers & Internet Logo
my pen drive has name as komal i want to rename it by rasika
No issue Just connect you pen drive in PC/ laptop. And after that connect your pen drive go to pen drive icon and right click- property- and change name.
Or simple way just connect your pen drive then press f2 and change name.
Technical Support
Feb 05, 2014 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
4 GB sandisk pendrive can't open
1. continue without solving
2. If you didn't remove the drive with the safe removal tool in the task bar ( lower right hand corner) the drive will lose it's ability to be mounted or seen by Windows and will not format. You will lose data.
Apr 20, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
pen drive is not detecting
1. Connect your pen drive to some other USB ports present at the rear side of your desktop pc.
2. In case of laptop, try connecting to some other available usb ports and check
3. In still not detected, then test your pen drive in some other systems.
4. If still not working, then it implies that your pen drive got detects.
5. If your pen drive is original kingston then you can claim the warranty from the place where you got it.
I hope this information is helpful for you
Thanks
Mar 14, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
4 gb pen drive give write protected error
Save the contents in the pen drive (this process will delete all the files in ur pen drive) and then download this http://www.apacer.com/en/support/downloads/Repair_v2.9.1.8A.zip,unzip it n run.....click "Format". Make sure u have connected only the pen drive u wanna recover to computer,this tool is very blind n it doesnt allow u to choose which removable drive to format..it formats the first removable disk (seems so). Gud luckmoz-screenshot.png
Feb 23, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
purchased a 4 gb pny pen today but wont allow me to transfer files to pen.message reads cannot find the specified file. make sure you specify the correct path and file name.any ideas
make sure that pen drive is recognize on your PC. try to check the pen drive's capacity. if you can see 0 bytes. It means that your pen drive is not recognized by the PC
Oct 30, 2008 | Computers & Internet
157 people viewed this tip
David Payne
David Payne
