Tip & How-To about Computers & Internet
How to enable & disable USB ports easily
If you need to disable USB devices from working accessing your system or prevent devices from working on usb ports (USB port blocking) create the following Registry file.
open note pad and copy/paste the following 2 lines
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\UsbStor]
"Start"=dword:00000004
save the file name as
disableUSB.reg
when you double click the file it will disable all usb ports on your system ..and preventing anyone from installing or copying files to/from your system and usb devices will no longer work
to reverse this process/access do the same as above but copy/paste these 2 lines
"Start"=dword:00000003
enableUSB.reg
Now when you double click the file it will enable all usb ports on your system ..and allowing access to installing or copying files to/from your system and connecting devices to your system.
This has been tested on WIndows 98/XP ..and may not work on Vista/Windows 7
Computers & Internet Logo
Hi. The USB ports on my lenovo y430 seem not to be working, as the computer does not recognize my external harddisks or external dvd writer. Is there any way I can fix this myself?
If you have tried every USB port and you use another USB device to it.. You may check the device manager ryanpajaro20_7.jpg and check if the USB controllers are disabled.. If not, you may click View and then click Scan Hardware Changes.. If still won't work, that is time that you call lenovo and have you laptop replaced defective USB ports..
Mar 21, 2011 | Lenovo IdeaPad Y430-3231U Notebook
device media is write protected
To disable writing access to USB drives and make all USB drives has only read-only access, follow these steps:
  1. Run Registry Editor (regedit).
  2. Navigate to the following registry key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control
  3. Create a New Key named as StorageDevicePolicies.
  4. Highlight StorageDevicePolicies, and then create a New DWORD (32-bit) Value named as WriteProtect.
  5. Double click on WriteProtect, and set its value data to 1. write-protect-usb.jpg
Once set, all users on the computer is now blocked and prevented from copying, transferring or writing any files, documents and data to the USB disk drives, without the need to restart or reboot computer. Any attempt to download or copy files to USB drive will return the following error message:
The disk is write protected.
The media is write-protected.
Remove the write protection or use another disk.
usb-removable-disk-write-protected.jpg To revert and remove the blocked write access to USB drivers, just delete the StorageDevicePolicies registry key, or delete the WriteProtect registry entry, or change the value data for WriteProtect to 0.
For user who doesn't want to manually editing the registry, simply download the following registry registration files to enable or disable the write protection (block writing attempt) to USB removable drive. Double click the .reg file unpacked from the .zip archive to merge the registry key entries.
Download DisableWriteToUSB.reg
Download EnableWriteToUSB.reg
The trick works in Windows XP SP2 and SP3, Windows Vista, Windows Server 2003 and 2008.
Feb 27, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Damaged USB Port
Ok I think the best method to "Fix" this would be to get your self a 4 - 5 port USB card, they are, real cheap, insert it into a spare slot, inside your PC, and install the drivers, if any, and use that one. And simply ignore the other one all together.
Feb 18, 2010 | Gateway Essential 400 PC Desktop
the usb ports will not work,therefore the mouse nor the keyboard will work
Try the mouse in a computer where the USB ports *DO* work.
It is possible that your system does not have the correct "device-drivers" for the USB ports. Thus, those USB ports seem to be "dead".
Turn the computer off.
Connect a PS/2 keyboard and a PS/2 mouse.
Turn the computer on.
Click START
Click Control Panel
Click System
Click Hardware
Click Device Manager
Expand the "USB ports" section of the tree.
Look for "yellow" or "red" marks.
Double-click one of those "problem" devices.
Choose "Reinstall Driver".
If it asks to be able to connect to the Internet, click "yes, this time".
Hopefully, this will install the correct drivers for your USB ports.
Nov 05, 2009 | Dell 2 Button Mouse 6u226
391 people viewed this tip
David Payne
David Payne
