Tip & How-To about Washing Machines
Whirlpool: How to replace the coupler on a direct drive washer
Removing the cabinet
UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screws are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them. Now the cabinet will lift off the frame and you can set it aside.
How to replace a coupler Now that the cabinet is out of the way, remove the pump from the motor and set the pump off to the side. Remove the two screws holding the clips on the motor and remove the clips. Unplug the motor harness and on some models you will need to unplug the capacitor.
Now you will need to replace all three parts to the coupler. I use a ½” socket and a small hammer to force the coupler onto the motor and transmission shafts. Put the rubber part onto the coupler half on the transmission and then line up the post on the motor shaft with the holes on the rubber part and it should go on ok. Put the clips that hold the motor in place and plug in the harnesses.
Put the pump back on and the clips to hold it in place. Set the cabinet back on the frame. Make sure the lip on the front cabinet is under the front rail of the frame. Ease the cabinet on the frame making sure the two rear sides of the cabinet set down on the tabs of the frame.
Put the two clips back on that hold the cabinet and plug the lid switch back in. Fasten the control panel down and you are all set.
Washing Machines Logo
Whirlpool top load washer will not agitate or spin.
Hi, If the motor runs but the washer will not spin or agitate, you will need to change the coupler. Here are the instuctions
Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screw are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them. Now the cabinet will lift off the frame and you can set it aside.
How to replace a coupler:
Vic
Jul 18, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
how do I remove or lift the top on my Kenmore washer to get to the lid sensor 110.24642300
You can access the lid switch once the cabinet is off.
Please let me knwo if I can assist you further.
Vic
Jul 01, 2009 | Kenmore 24032\24036 Top Load Washer
How do I take off the back and top of a top loading Roper washer?
Hi, The whole cabinet has to come off. Here is how to do this:
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 01, 2009 | Roper RTW4300SQ Top Load Washer
Describe your Kenmore 24032 \ 24036 Top Load
Hi, Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screw are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them.
If this is not your model, please let me know the model# so I can help you.
Vic
Jun 28, 2009 | Kenmore 24032\24036 Top Load Washer
I need to replace the pump on Kitchenaid clothes dryer
I hope this helps. Please let me knwo if I can assist you further.
Vic
Jun 19, 2009 | KitchenAid KAWS850L Top Load Washer
177 people viewed this tip
Top Washing Machines Experts
