Tip & How-To about Televison & Video
Jvc dvd and vhs combe hard reset fixes loading issu's and more
If you have any jvc dvd and or dvd , vhs combo and you have error codes or loading issue's a hard reset may fix this issue and is the step you should always preform before sending it in for service or giving up on it.
a hard reset is done by simply holding the power button and stop button at the same time until the unit turns off. turn unit back on and it will go back to base settings.
if this does not fix your issue service is required.
Televison & Video Logo
error 0507
see the cause and fix it:
1 alternative for playing DVD:
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
2ND ALTERNATIVE: FOR VHS RECORDING:
play the VHS TAPE CLEANING , FOR clean the sensors, rollers, drum etc.
b) Try it.
c)Otherwise you must go to the repair shop TV for fix it.
God bless you
Jul 21, 2012 | Samsung VR-325 DVD Recorder / VCR Combo
I have a JVC DVD- VHS Combo Player. Model #
Unplug it and wait 5min plug it back in and sometines it will work, I have three units they all do the same thing , with two of them the unpluging no longer works. I can't find anyone who knows whats wrong either
Sep 05, 2009 | JVC HR-XVC30U DVD Player/VCR
LOADING
It is pretty common problem.
If all of your DVDs are having same problems,
it is most likely either optical sensor is at fault. The other could be the actual loading mechanism problem.
If the dvd tray(drawer) closes all the way in but the DVD disc never completes the loading(reading) procedures, 1) it could be simply dirty or damaged disc. 2) the optical pickup device (eye) is dirty or just went defective. 3) sometimes the drawer tray that houses the DVD did not complete to engage in disc reading position can produce this result.
I would suggest: first check the position of the drawer and condition(s) of your DVD disc itself.
If the pickup device(optical eye) is dirty or defective, that needs to be serviced by a qualified technician. or contact JVC service center. Their information can be found at
http://support.jvc.com/consumer/support/support.jsp?pageID=10
Feb 13, 2008 | JVC DR-MV1SU DVD Recorder/VCR
289 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
