Tip & How-To about Sewing Machines
How To Thread Your Sewing Machine
“How Do I Thread My Machine?”
A Basic Guide to Threading a Sewing Machine
Sewing Machines Logo
My pfaff2044 started sewing uneven stitches. It can sew nice then next second leave a big stretch then sew normal again and then itll leave a bigger stretch it also wont blind stitch.
3 Common Sewing Machine Problems (and How to Fix Them)
www.marthastewart.com/.../common-sewing-machine-rep...
Martha StewartSep 26, 2014 - We consulted Becky Hanson of Singer Sewing Company for her tips on ... The Problem: Stitches are coming out uneven or skipping entirely.
Basic Sewing Machine Troubleshooting - Sewing School
sewingschool.org/2011/03/16/basic-sewing-machine-troubleshooting/
Mar 16, 2011 - The thread breaks, my needle bends, or skipped stitches - UGH! Don't get ... Problem: My stitches are uneven and sometimes skipping!
My stitches are coming out uneven - SewingSupport.com
www.sewingsupport.com/sewing.../sewingsupport.../sewing.../my-stitches...
What to do if the stitches from your sewing machine are coming out uneven. Sewingmachine troubleshooting guide.
Dec 12, 2015 | Sewing Machines
trhreading
http://cgi.ebay.com/Euro-Pro-Deluxe-Denim-Silk-Sewing-Machine-EP-377_W0QQitemZ8271336746QQcategoryZ3118QQcmdZViewItem#ebayphotohosting If so it threads just like my sewing machine.Draw your thread across the top,down into the first slot,then up and thru the second slot,come down,pass it thru the thread guide on the needle,then thread your needle.Most all machines are basic when it comes to threading.HTH
Kathi
May 20, 2009 | Sewing Machines
threading a husqvarna huskylock 1001L serger
Solution taken from "Handbook for Huskylock Sewing Machine Models 1001L/1000L/1000"
1. Raise the presser foot by using presser foot lever. When the presser foot is raised, the two thread tension discs in the thread tension control panel are released so that thread passes freely between them. Otherwise thread tension may not be correct.
Important! When threading the needle, always be sure to lift the presser foot lever, and also take care to thread in the proper order.
Threading order:
1. Upper looper thread (green)
2. Lower looper thread (blue)
3. Double chain stitch looper thread (purple) in case of 5 thread stitch or double chain stitch
4. Right needle thread (red)
5. Left needle thread or double chain needle thread (yellow)
Caution!
Because the left thread tension dial (yellow) is used for either the left needle or the double chain stitch needle, these needles will never be used at the same time.
Upper looper (green) sequence:
1. Thread holder (silver triangle openings attached to thread holder stand)
2. Thread guide (flat silver clips just behind thread tension disc)
3. Thread tension disc (circular knobs with numbers for tension setting)
4. Pull thread around upper looper guide and upper looper
5. Pull thread into hole of upper looper
Lower looper (blue)
Repeat 1, 2, 3.
4. Pull thread around guide (see color coded chart inside front serger cover).
Easy threading mechanism (for lower looper)
1. Pull out the lower looper threading lever
2. Thread the lower looper and position the thread on hook of the lower looper
threading lever.
3. Push the lower looper threading lever back to its basic position while
holding the end of the thread.
Caution:
When returning the lower looper threading lever, always make sure that the two
blue triangle marks (directional arrows) meet each other.
Left needle thread (yellow)
Important: Thread the needles after threading of lower looper and upper looper.
First raise the presser foot lever, and then thread the needle threads in order shown in color coded thread guide.
Jun 24, 2008 | Sewing Machines
need manual for 11301 barbie sewing machine
Anyone who needs a Manual for this Barbie machine I have it in pdf.
Someone tell me if they want it posted.
thanks,
Bonnie
May 03, 2008 | Barbie 11301 Mechanical Sewing Machine
Threading my sewing machine
Go to http://www.singerco.com/accessories/manuals.html And type the model number in the manual search. Reading your message again, it might be that you have already downloaded the free one. Sorry if this is case. There is however a generic threading guide here http://www.singerco.com/resources/threading.html Hope this helps a little! Regards
Sep 24, 2007 | Sewing Machines
704 people viewed this tip
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
