Tip & How-To about Audio Players & Recorders
How to unlock a dvd player
  1. Locate your DVD player's brand name and model number. These can usually be found on the box the DVD player came in, or on a sticker close to the video inputs or on the bottom of the DVD player.
  2. Have your remote handy. You will need your remote to enter the input codes into your DVD player.
  3. Locate a Web site that can help you with the codes you need for your particular DVD player, since all DVD players have different codes. Try dvdexploder or dvdunlockcodes.com, they both have an extensive list of codes for almost every kind of DVD player manufactured.
  4. Enter your brand name and model number when prompted to do so on the Web site. If your particular model number is not available, try searching under the brand name. Sometimes you will be able to find a model number that is close to your DVD player's model number.
  5. Enter the codes into your DVD player with your remote. Be sure the DVD player's door is open-almost all codes require the door to be open.
  6. Test the player and that should be it.
Tesco's compact DVD player how do I change the region
see the steps and fix it God bless you
    • 1 Purchase or borrow an imported DVD. The only real reason to make your DVD player region-free is if you plan on watching imported DVDs.
    • 2 Locate your DVD player's brand name and model number. These can usually be found on the box the DVD player came in, or on a sticker close to the video inputs or on the bottom of the DVD player.
    • 3 Have your remote handy. You will need your remote to enter the input codes into your DVD player.
    • 4 Locate a Web site that can help you with the codes you need for your particular DVD player, since all DVD players have different codes. Try DVD Exploder or Video Help (see Resources below). Both have an extensive list of codes for almost every kind of DVD player manufactured.
    • 5 Enter your brand name and model number when prompted to do so on the Web site. If your particular model number is not available, try searching under the brand name. Sometimes you will be able to find a model number that is close to your DVD player's model number.
    • 6 Enter the codes into your DVD player with your remote. Be sure the DVD player's door is open-almost all codes require the door to be open.
    • 7 Test your imported DVD to see if it works, once you have entered your code into the DVD player.
Oct 01, 2012 | Televison & Video
how to unlock mitsubish dd6030
follow the steps: God bless you
  • Jul 20, 2012 | Mitsubishi DD-6030 DVD Player
    unlocking mitsubishi dd 6030
    follow the next step:God bless you
    UNLOCKING REGION 1 CODES
    see the following steps: God bless you
  • Jul 20, 2012 | Sony BDP-S360 DVD Player
    unlock code for all region
  • Jul 20, 2012 | Televison & Video
    205 people viewed this tip
     Grubhead
    Grubhead
