Tip & How-To about Computers & Internet
Formatting an external hard drive with Mac OS X's Disk Utility
Formatting your new external hard drive is not as difficult as you may think. In fact, you don't even have to be a computer techie or uber-Mac geek to perform this procedure successfully.
The tool you would use, to format your drive within your Mac OS X system, is the built-in utility application called Disk Utility.
Disk Utility is Apple Inc.'s defacto utility application, for performing disk related tasks within the Mac OS X volume.
From creating new images, to burning CDs and DVDs to formatting hard drives, Disk Utility performs well enough to keep not only your Mac OS X volume on your hard drive error free, but keep your hard drive healthy and error-free as well.
I could go on in detail, admirably describing more features of this versatile Mac OS X tool, but the purpose of this FixYa tip, is to show you how to easily format your external hard drive. So that is where I will take you now.
There are generally two formats in Disk Utility that you can use to effectively format your hard drive.
Mac OS Extended (Journaled) - if you want a Mac readable hard drive only
MS-DOS (FAT 32) - If you want your external hard drive to be read by both Mac and PC.
--STEPS FOR FORMATTING YOUR HARD DRIVE WITH DISK UTILITY--
• First, make sure your external hard drive is connected securely to your Mac and is turned on.
•Next, from your desktop, click anywhere on a blank space on your desktop. Now you should see Finder listed near the Apple menu icon.
• From the Finder menu, click on Go, then Utilities from the
drop-down menu. This will take you to your Utilities* folder.
(*You can also get to the Disk Utility application via Applications > Utilities folder)
• Now, locate and launch the Disk Utility application.
When Disk Utility opens you will see a left side window, which will show
all connected hard drives and optical drives. It is here that you
should see your external hard drive listed in that window.
• When you locate it, simply select it and then select Partition
from the tabs on the right hand side.
• Change the Volume Scheme from Current to 1 Partition
• Make sure to provide a name for your new external hard drive.
• Select Mac OS Extended (Journaled) from the Format
drop down menu, for a bootable Mac only external hard drive.
• Or select MS-DOS from the Format drop down menu, for a bootable Mac & PC external hard drive.
From there, click the Options button, located toward the bottom of
your window.
This will open a partition scheme selection window as seen in this screen shot:
• Select GUID Partition Table for bootability on a Intel processor based
Mac.
• Or select the Apple Partition Map for bootability on a PowerPC based Mac.
• Click the OK button.
Finally, click the Partition button and allow Disk Utility to format your new external hard drive.
When this process is complete, you now have a newly formatted, ready to use hard drive.
Believe it or not, this process can be completed faster than you think.
Using this method with Disk Utility, I was able to format my new 1TB Iomega USB external in less than 20 minutes.
Final Note:
I used the external hard drive as the focus for showing you how to format and prepare your hard drive for use on your Mac, but this feature can also work with internal hard drives as well.
For more information about some of the disk repairing features of Disk Utility, here is a great support link for this nifty and quite effective Apple utility for the Mac OS X platforms:
Using Disk Utility to repair a disk
Thanks for reviewing my Mac OS X Tip!
Regards,
-Mactechtrainer
Computers & Internet Logo
How do I recover lost data?
If the computer won't even turn on its most likely a non-hard drive issue, which is a GOOD thing. Your lost itunes data can be successfully recovered by following these steps:
--uninstall or remove the current hard drive (on the broken computer) ---buy an external casing that fits your type of hard drive (take old hard drive with you to store or write down the name and model number to insure you are picking the correct case).
--connect the old hard drive into the new external case
--connect external case to a working computer through a USB input.
--find and explore the old hard drive on new computer screen,
--locate itunes folder
--copy the entire itunes folder or choose which files you want from the old hard drive and paste in itunes folder on the working computer and you are done.
If you are not computer savvy, unsure about what a hard drive might even be or just don't feel like doing it yourself the above solution can be done by Staple's or have The Geek Squad have a go at it.
Good luck and hope this helps you !
May 30, 2012 | Apple G3 Computers & Internet
formatting for Mac
What do you mean?Want to recover data from formatted hard drive?
Data Recovery Software can help.
Tenorshare Data Recovery is a professional data recovery program that can recover data from hard drive after deeply scanning your drive to look for lost data you accidentally deleted or formatted.
Get it from: http://www.any-data-recovery.com/product/datarecoveryprofessional.htm
Aug 30, 2011 | Iomega eGo Portable Hard drive 500 GB ...
Looking for the Mac driver for a 500gb
A ahhhh Mac driver? A mac should just pick up the fact that you plug in an external drive. It might even detect if it's formatted Windows NTFS. You probably have to format it for Mac OS.
http://www.ehow.com/how_2063795_format-hard-drive-mac-os.html
Nov 23, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
One Touch 4 Maxstor 750 external hard drive installing on a macbook pro
If you have a hard-drive that is formatted as NTFS which stands for (New Technology File Ssytem), Mac OS X can only read the partition. It cannot write to it.
The trick is to use your drive manfacturer's disk-formatting software which will allow you to format your drive as one large partition. Formatting your drive as one large FAT 32 partition is the easiest way to make a drive so it can be used with both PC's and Mac's.
Another option is to use a third part utility so that you can read a MAC formated harddrive's from your PC. Here is one option: http://www.macdrive.com/.
Good luck.
SeekPCRepair
Feb 08, 2008 | Computers & Internet
6,884 people viewed this tip
David Payne
David Payne
