Tip & How-To about Computers & Internet
Generic instruction on how to connect your WiFi Router to the Internet
Yes, try this, Using the network cable that came with your wireless router, you should temporarily connect your computer to one of the open network ports on your wireless router (any port that isn't labeled Internet, WAN, or WLAN). If you need to, turn your computer on. It should automatically connect to your router.Next, open Internet Explorer and type in the address to configure your router. You might be prompted for a password. The address and password you use will vary depending on what type of router you have, so refer to the instructions included with your router. As a quick reference, this table shows the default addresses, usernames, and passwords for some common router manufactures. Table is, Router Address, User Password. 3Com http://192.168.1.1 admin adminD-Link http://192.168.0.1 admin Linksys http://192.168.1.1 admin adminMicrosoft http://192.168.2.1 admin adminNetgear http://192.168.0.1 admin password
Internet Explorer will show your router's configuration page. Most of the default settings should be fine, but you should configure three things: 1. Your wireless network name, known as the SSID. This name identifies your network. You should choose something unique that none of your neighbors will be using. 2. Wireless encryption (WEP) or Wi-Fi Protected Access (WPA), which help protect your wireless network. For most routers, you will provide a passphrase that your router uses to generate several keys. Make sure your passphrase is unique and long (you don't need to memorize it). 3. Your administrative password, which controls your wireless network. Just like any other password, it should not be a word that you can find in the dictionary, and it should be a combination of letters, numbers, and symbols. Be sure you can remember this password, because you'll need it if you ever have to change your router's settings. The exact steps you follow to configure these settings will vary depending on the type of router you have. After each configuration setting, be sure to click Save Settings, Apply, or OK to save your changes. Now, you should disconnect the network cable from your computer.
Computers & Internet Logo
Can not connect to my wireless router
1. Choose your wireless equipment The first step is to make sure that you have the equipment you need. As you're looking for products in stores or on the Internet, you might notice that you can choose equipment that supports three different wireless networking technologies: 802.11a, 802.11b, and 802.11g. We recommend 802.11g, because it offers excellent performance and is compatible with almost everything.
Shopping list
  • Broadband Internet connection
  • Wireless router
  • A computer with built-in wireless networking support or a wireless network adapter
A wireless router
The router converts the signals coming across your Internet connection into a wireless broadcast, sort of like a cordless phone base station. Be sure to get a wireless router, and not a wireless access point.
A wireless network adapter
Network adapters wirelessly connect your computer to your wireless router. If you have a newer computer you may already have wireless capabilities built in. If this is the case, then you will not need a wireless network adapter. If you need to purchase an adapter for a desktop computer, buy a USB wireless network adapter. If you have a laptop, buy a PC card-based network adapter. Make sure that you have one adapter for every computer on your network.
Note: To make setup easy, choose a network adapter made by the same vendor that made your wireless router. For example, if you find a good price on a Linksys router, choose a Linksys network adapter to go with it. To make shopping even easier, buy a bundle, such as those available from D-Link, Netgear, Linksys, Microsoft, and Buffalo. If you have a desktop computer, make sure that you have an available USB port to plug the wireless network adapter into. If you don't have any open USB ports, buy a hub to add additional ports.
2. Connect your wireless router Since you'll be temporarily disconnected from the Internet, print these instructions before you go any further.
First, locate your cable modem or DSL modem and unplug it to turn it off.
Next, connect your wireless router to your modem. Your modem should stay connected directly to the Internet. Later, after you've hooked everything up, your computer will wirelessly connect to your router, and the router will send communications through your modem to the Internet.
  • If you currently have your computer connected directly to your modem: Unplug the network cable from the back of your computer, and plug it into the port labeled Internet, WAN, or WLAN on the back of your router.
  • If you do not currently have a computer connected to the Internet: Plug one end of a network cable (included with your router) into your modem, and plug the other end of the network cable into the Internet, WAN, or WLAN port on your wireless router.
  • If you currently have your computer connected to a router: Unplug the network cable connected to the Internet, WAN, or WLAN port from your current router, and plug this end of the cable into the Internet, WAN, or WLAN port on your wireless router. Then, unplug any other network cables, and plug them into the available ports on your wireless router. You no longer need your original router, because your new wireless router replaces it.
  • 3. Configure your wireless router
  • Using the network cable that came with your wireless router, you should temporarily connect your computer to one of the open network ports on your wireless router (any port that isn't labeled Internet, WAN, or WLAN). If you need to, turn your computer on. It should automatically connect to your router.
    As a quick reference, this table shows the default addresses, usernames, and passwords for some common router manufacturers.
    Router
    Address
    Username
    Password
    3Com
    http://192.168.1.1
    admin
    admin
    D-Link
    http://192.168.0.1
    admin
    Linksys
    http://192.168.1.1
    admin
    admin
    Microsoft Broadband
    http://192.168.2.1
    admin
    admin
    Netgear
    http://192.168.0.1
    admin
    password
    4. Connect your computers to the wireless network If your computer does not have wireless network support built in, plug your network adapter into your USB port, and place the antenna on top of your computer (in the case of a desktop computer), or insert the network adapter into an empty PC card slot (in the case of a laptop). Windows will automatically detect the new adapter, and may prompt you to insert the CD that came with your adapter. The on-screen instructions will guide you through the configuration process.
Mar 24, 2010 | HP Pavilion dv9000z Notebook
Trying to get security key to set-up new laptop - Model WG4614
Connect to it using a network cable temporarily instead of wireless and go to its configuration screen to set the security key yourself. You might have to reset the thing first. Instructions for doing all that are here: http://kb.netgear.com/app/products/family/a_id/1296). You'll need to select the right router version, apparently, to get the right manual.
Feb 24, 2010 | NetGear WGR614 Wireless Router
is there anyway to get internet cinnection without having a cd driver for internet?
Yes, try this, Using the network cable that came with your wireless router, you should temporarily connect your computer to one of the open network ports on your wireless router (any port that isn't labeled Internet, WAN, or WLAN). If you need to, turn your computer on. It should automatically connect to your router. Next, open Internet Explorer and type in the address to configure your router. You might be prompted for a password. The address and password you use will vary depending on what type of router you have, so refer to the instructions included with your router. As a quick reference, this table shows the default addresses, usernames, and passwords for some common router manufacture Router Address User Password 3Com http://192.168.1.1 admin admin D-Link http://192.168.0.1 admin Linksys http://192.168.1.1 admin admin Microsoft http://192.168.2.1 admin admin Netgear http://192.168.0.1 admin password
Feb 11, 2010 | Computers & Internet
Can both a computer without wireless netcard also be connected to a wireless modem by cable at the same time as another computer is connected using the wireless settings?
Yes, the wireless router can connect several wireless connected computer at the same time as well as computers using a network cable depending the maximum number LAN ports available on the wireless router.
Jan 26, 2010 | Computers & Internet
Can I connect this if I don't have a desktop computer
You can connect one of the laptops using an ethernet cable and configure the router.
If you need instructions I can post them here, use "Chat Live Now" or Premium to get yor answer
Let me know if you need further help
ta, HPC
Jan 24, 2009 | NetGear RangeMax WPN824 Wireless Router...
147 people viewed this tip
David Payne
David Payne
