Tip & How-To about Cell Phones
How to Bluetooth Connect your Phone to your PC.
How do I connect my bluetooth phone with my computer? First you need to turn your phones visibility on. Most phones you do this by going into the menu, settings and they should be an option for "connections." Bluetooth will or should be under your connects, like I said this is for most phones. You need to first make sure your bluetooth is turned on. Next you need to turn on your bluetooth's visability.
As far as your computer goes. You either need a laptop/tower with bluetooth build in or a bluetooth USB adapter. You can generally get a bluetooth USB adapter for less than $30, and these are very useful and can be used with multiple phones, which is great about bluetooth.
After you have your bluetooth USB installed on your computer, then you need to sync them together. The easiest way that I have found to do this is to do it from the phone. Under your bluetooth settings under your phone, they should be an option to search for new devices or to pair it. Once your perform the search it should find your computer. Select to pair it with your computer. It will ask you for the passcode on the phone it should be "0000" that is four zeros. You should get a pop up from the system tray on a windows machine asking if you want to pair your bluetooth with this device. You need to tell it yes and it will *** for the passcode, which again is four zeros "0000." You should then be ready to use your bluetooth enabled phone with your computer.
Cell Phones Logo
how do i disable bluetooth on my SGH A561 samsung flip phone
To disableset Bluetooth on your phone
1. Go to Menu, select Connect or Connections or Connectivity:
Note! If the above steps do not work, please consult the user manual.
2. Bluetooth - Select On to disable Bluetooth.
3. My telephone's visibility - Select Shown to all if you want your device to be found by other Bluetooth devices. If you select Hidden, your device cannot be found by other devices.
4. My Bluetooth name - Define a name for your device. After you have activated your Bluetooth service and changed My phone's visibility to Shown to all, your phone and this name can be seen by other Bluetooth device users.
Hope that helps..
Thanks for using fixya.....
Jan 08, 2011 | Cell Phones
i want to be able to put the videos I record from my phone onto my computer how do u do that...
This may or may not work. Connect phone with USB to computer. Click start, then "computer". Right click on removable disk (F:). Click "open as removable device". If you are able to access the phone's files, you should find a folder containing your videos.
However, here's a better way. Connect your device to your computer using bluetooth. Both devices will have to be bluetooth enabled. On your phone go to "settings", then "wireless and network", then "bluetooth". Click "enable bluetooth". Also click "visible" so your computer will recognize the device.
Now click "scan".
If your phone does not find your computer. Then go to your computer. Click start, and type in "bluetooth". Choose bluetooth device to add your phone. Your phone should be "visible" so your computer can find it and add it.
On your computer you can use the transfer wizard (just click start then type in bluetooth) and click "receive a file" and click "next" or on your camera go to the video folder, highlight it, click menu, then click share, there should be quite a list, choose "bluetooth". Your phone should scan and find your computer. Voila!
Dec 30, 2010 | Samsung Galaxy S GTI9000 Smartphone
How do I connect my LG Neon to my bluetooth?
you have to:
go to settings on the phone
then go to connection
then go to bluetooth
turn on
turn visibility on
and search for new devices
depending on what you are trying to connect ex. bluetooth headset it should find it and if you are using a computer you sometimes have to change some sttings on your computer
Mar 20, 2010 | LG Neon GT365 Cell Phone
HOW DO I CONNECT MY CELLULAR TO MY LAPTOP VIA BLUTOOTH M
Feb 11, 2010 | Cell Phones
HOW DO I CONNECT MY CEL TO MY LAPTOP VIA BLUETOOTH
Feb 10, 2010 | Cell Phones
239 people viewed this tip
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
