Tip & How-To about Apple iPod touch
How to reset forgotten password Apple Ipod Touch.
Try a soft reset and hard reset your iPod Touch if it’s frozen or not responding.
Try a soft reset first:
1. Press and hold theSleep/Wake button on the top of the unit until a red slider appears
2. Drag the slider.
3. Press and hold theSleep/Wake button until the Apple logo appears.
If a soft reset doesn’t work, try a hard reset:
Press and hold both the Sleep/Wake button and the Home button for about ten seconds, until the Apple logo appears.
Apple iPod touch Logo
my i pod will not respond to anything wont turn on wont take a charge nothing at all do i have to replace the battery
Sounds like your ipod has frozen. Try this:
2. Drag the slider.
If a soft reset doesn't work, try a hard reset:
Mar 06, 2011 | Apple iPod touch
my apple ipod 32G does not turn on.
Seems like your iPod has frozen.
2. Drag the slider.
My ipod is disableb because my little brother kept putting in the wrong pass code and i dont know how to fix it
2. Drag the slider.
Feb 11, 2010 | Apple iPod touch
my daughter forgot her 4 digit password how do we unlock it
Hello. This will step you through the process of restoring your iPod Touch2_bing.gif to factory settings. Please remember that this will erase all of your files, settings, and data stored on your device.
  1. Connect your iPod to your computer.
  2. Select your iPod2_bing.gif when it appears in iTunes under Devices.
  3. Select the Summary tab and then the Restore option.
  4. Select the Restore option when iTunes2_bing.gif prompts you.
  5. Once the restore process has completed the, iPod touch restarts and displays the Apple2_bing.gif logo while starting up.
  6. Select "Set up as new…"
Hope this helps. Good luck.
Feb 10, 2010 | Apple iPod touch
My Ipod Touch Is Diabled Due To I Dnt No My Password
iTunes will only let you restore the iPod if you turn it off, hold the menu button and then plug in the usb cord connected to the computer as you are holding the menu button. the iphone will start in recovery mode and itunes will offer the restore. after that you will be password free, but your data will be erased, if you did a sync recently though, you can restore it from itunes. i work for an iphone repair shop and we do this repair frequently.
Dec 01, 2008 | Apple iPod touch
793 people viewed this tip
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
