Tip & How-To about Computers & Internet
Installing and Uninstalling a new software .
Here i want to mention an important issue regarding rebooting after installing and uninstalling any software on the PC . It's very important to reboot after installing and
uninstalling any software on the system , so that software runs smoothly on your system.
Never forget that .
Computers & Internet Logo
Error message says a double paper feed has occured and it is not double feeding. Any suggestions?
This is a known problem with the Canon P-150. I have spend countless hours on the phone (our company deployed 150 of these) trying to resolve this. The best bet is to unplug the scanner, reboot the computer, and then try again. It is usually a memory allocation issue. If the issue persists. Uninstall the "canon p-150 driver" enter, msconfig, disable all non-microsoft services, reboot, install scanner, re-enable all services and then reboot. Canon knows of this error, and what I just mentioned is what their tech support recommends. There is also a known issue with symantec or norton products interfering with the twain software interface.
May 09, 2012 | Canon P150 Portable Scanner
I have window s 7 on my pc & I have deep freeze 7 installed on it and i deep frozen my drive c,but after some virus problem my all drive have been deep freezed and now the deep freeze program not running and showing icon & every thing i save to my cop. is going deleting every time. so tell me the easy way to run or unfreeze or uninstall the programe. thank u
To uninstall the software Deep Freeze must first be disabled and then uninstalled.
To disable Deep Freeze:
  1. Hold down the shift key and double-click on the Deep Freeze icon. Alternatively, you can press Crtl-Alt-Shift-F6. You should now see a password dialog.
  2. Enter your password and click OK. If you have not yet entered a password you should be able to click OK without entering anything. You should now see a dialog with boot options.
  3. Select "Boot thawed" and click OK. This will disable Deep Freeze on the next reboot.
  4. Reboot your machine. After the machine reboots you are ready to uninstall Deep Freeze.
To uninstall:
  1. Locate the installation file you used to install Deep Freeze to this machine. By default the name of this file is called "DF5Std.exe" for versions 5.X and "DF6Std.exe" for versions 6.X.
  2. Run the installation file (DF5Std.exe or DF6Std.exe).
  3. Select the option to "Uninstall"
  4. The software should uninstall and reboot the machine. When the machine reboots, Deep Freeze should be uninstalled.
Please comment if the information has been helpful. Thank you and regards.
Aug 25, 2010 | Computers & Internet
how to uninstall deep freeze 6?
You havent mentioned the O/S you are using, try this if its XP
Here the small tricks to disable or unintal Deep Freeze ver 6 without password:
  1. Boot your computer from Windows XP Installer
  2. After appear “Enter to Setup” option, Press Enter then press F8.
  3. Selected R to repair Windows system ( Repair Setup)
  4. Continue repairing/installing windows untill finish.
  5. Prepare the Deepfreeze v.6 installed, open the file like you want to install the software.
  6. it’s will show “Uninstall Deep-freeze” options. Uninstall the software, after uninstall finished reboot your computer.
  7. Now the Deep-freeze has removed from your computer.
FOR VISTA / WIN 7
Power Off the PC
Start the PC and Press F8 key till you get Boot options,
Start the PC is SAFE MODE and try to uninstall it.
Jul 06, 2010 | Computers & Internet
samihullah
To uninstall:
Mar 15, 2010 | Sony VAIO PCV-W600G PC Desktop
no sound or vision
If the installation went Ok, then you need to reboot your machine. That usually causes the installation to detect the new device, and a series of screens will prompt you for certain things, among which one of them is setting up your audio and your video.
If you're using Vista, and if the installation ran into trouble, you should have seen a dialog asking you whether the install was Ok or not.
Did you see this dialog and what did you answer, if anything?
If rebooting fails, I would go to the Control Panel->Programs->Uninstall a Program and uninstall the camera software.
Reboot and try to install the software again. One important thing. Do not connect the camera until asked to do so. This may cause the installation to fail.
Aug 16, 2009 | Microsoft Office Outlook 2003 for PC
87 people viewed this tip
David Payne
David Payne
