Tip & How-To about Cell Phones
How to master reset any samsung mobile phone
If you have forgot your password or just want to reset your phone follow these steps.
1. Remove your battery (and sim card if your phone has a sim card.)
2. Replace just your battery and power the phone back on.
3. When the phone powers on type in *2767*3855#
Your phone will power off then back on with the out of box settings,
Keep in mind that doing this will also clear any information including contacts and pictures.
Cell Phones Logo
hi i am looking for the password for my samsung tocco lite that is standerdly set
The default password is 00000000 (8 zeros in a row).
If you have already set a pin and you have forgot it, follow these steps: *2767*3855#
Use this to reset your phone if you have forgot your pin number
Turn of phone remove battery, then remove sim card, replace battery without sim card, turn phone on and enter code, then wait for phone to reboot itself (do not turn phone off as this could cause problems, so make sure plenty of charge is in the battery). When it has rebooted it is now unlocked.
Mar 06, 2011 | Computers & Internet
i forgot my phone password for my samsung gt - s5233w , how can i revive my password ?
the only solution i have is...
1. turn off your phone and remove your sim card.
2. turn it on again (without sim) wait until it reach in main menu..
3. type *2767*3855# which is full reset.
4. follow the ramaining procedure...
Feb 02, 2011 | Samsung Cell Phones
this happens all the time with samsungs. i went to tmobile.com/forums and found some info to fix mine when i forgot mine as well lol. the problem is it will reset your password and all your other information as well :(
A phone lock or security code on most Samsung handsets can be overridden by performing a full reset on the device. This will set the security codes on the handset back to the default eight zero's (00000000).
Important: This reset restores the original factory settings and will erase all downloaded content, including ringtones, images, programs, and contacts stored in the internal memory. It does not erase data stored on the SIM card or memory card (if available). Make sure you have backed up contacts, calendar appointments, and other data before continuing.
1. Power off the handset
2. Remove the battery
3. Remove the SIM card
4. Reinsert battery ONLY
5. Turn handset on
6. At the Insert SIM prompt screen enter the following code: *2767*2878#
NOTE: If using a handset that was released after July 2009 use this code: *2767*3855#
7. The handset should display E2P custom reset
8. Power off handset
9. Reinsert SIM card
10. Power on handset
11. The phone should be unlocked
NOTE: If you didn't get a E2P custom reset or a Full reset message on the handset your Samsung model may need an MCK code. You will have to call technical support for this code. Please have your IMEI number ready to expedite the process for this code. Your IMEI number is located on a label on the back of the phone,under the battery.
Dec 24, 2010 | Samsung C3510 Cell Phone
my sister forgot the password to her phone
im sorry about that! the problem is all your info will be lost. you need to enter the following steps which will reset your code, but will also reset your phone and information. i found this at t-mobile.com/forums.
5. Turn handset on
Dec 24, 2010 | Samsung UpStage SPH-m620 Cellular Phone
unlock password code samsung b3210
May 28, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
1,956 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
