Tip & How-To about Computers & Internet
The settings saved on this computer for the network do not match the requirements
Many a times you must have come across a weird error message while using wireless connection on the computer with Vista operating system.
This error message generally appears when the existing wireless settings on your network have been modified or removed. You may either revert the wireless settings on your wireless router or access point or configure the concerned Vista computer to match the new wireless settings. Follow the below steps to configure the settings on the computer:
1. Click START, Click Control Panel then click classic view in left hand side
menu.
2. In the main screen, open up NETWORK AND SHARING CENTER.
3. In the left hand side menu open up MANAGE WIRELESS NETWORKS.
4. If you see any name in the list, please select the name and click remove.
5. Once the list is empty, click on ADD, select the first option, ADD A NETWORK THAT IS IN RANGE OF THE COMPUTER.
6. click on your network name SSID and click on connect. If you have a Password setup on the router enter the security key.
7. This should setup the wireless network.
To know about the security key or passphrase on your NETGEAR ROUTER'S please visit the below tip:
http://www.fixya.com/support/r4095687-check_wireless_security_key_or
For any other make of the router, please contact technical support of the concerned router.
Computers & Internet Logo
I have been using windows Vista for about 2 months and I shut the computer one night and now it states the validation code is invalid
If, when you try to activate Windows Vista on a computer that was obtained from an OEM, you experience one one of the following symptoms. Error message 1
Error Code: Invalid Volume License Key
Error message 2
Error Code: 0xC004F059
Description: The Software Licensing Service reported that a license in the computer BIOS is invalid.
You receive the following error message:
Error Code: 0xc004f035
The Software Licensing Service reported that the computer could not be activated with a Volume license product key. Volume licensed systems require upgrading from a qualified operating system. Please contact your system administrator or use a different type of key. Article KB94962 will help you. If the following error code or error message appears when users try to activate Windows Vista The activation key You typed is invalid This TechNet thread may prove to be of help. If you face Volume Activation error codes on Windows Vista-based computers, KB938450 will help you troubleshoot them.If, when you try to activate Windows Vista on a computer that was obtained from an OEM, you experience one one of the following symptoms.
Error message 1
Error message 2
If you face Volume Activation error codes on Windows Vista-based computers..
May 05, 2010 | Microsoft Windows? Vista Home Basic...
Traveling with Vista
re install your wireless drivers and try it ........
Dec 22, 2008 | Microsoft Windows Vista Ultimate Edition
Cannot Communicate from Computer to Computer
A connection from USB adapter directly to USB adapter may or may not be possible. Borrow a wireless router from someone and use it to test supporting connections to your two computers. I think you will find this a much easier way to proceed. Routers can be had for $40 or less. Shop around.
Good Luck
Gus
Nov 18, 2008 | Linksys Wireless-G WUSB54G 802.11g/b
Nintendo usb connector
hi coolsoph,
Firstly, take note that Windows Vista doesn't support the Nintendo USB connector (currently there is now way of making it work on Vista, hopefully this will be resolved with the release of Vista Service Pack 1).
Secondly, and this is if you are using Windows XP as your computer operating system, try these steps to enable XP to share it's Internet connection with other computer (for ex your Wii):
1. Click Start -> Control Panel
2. In Control Panel open the Network Connections applet
3. Right-click on your active connection (will be named something like "Local Area Connection" if you use a cable to connect to your router or "Wireless Network Connection" if you use a wireless technology to connect to your router).
4. Click on Properties
5. Select the Advanced tab
6. Check the box named "Allow other network users to connect through this computer's Internet connection" in the Internet Connection Sharing area.
7. For good measure you can restart your PC after checking the box
I hope this is helpful information and thanks for using the FixYa services
Regards
Feb 12, 2008 | Computers & Internet
124 people viewed this tip
David Payne
David Payne
