Tip & How-To about Computers & Internet
How to tell if your PC is 32 bit or 64 bit?
Open the "System Properties" window
If your Start menu is configured for Classic Start menu, right-click the My Computer icon on your desktop, and click Properties.
If your Start menu is the Windows default Start menu, click the Start button, then right-click the My Computer icon in your Start menu, and click Properties.
Click the Advanced tab.
Click Environment Variables.
In the "System variables" list at the bottom of the Environment Variables window, look for a variable called "PROCESSOR_ARCHITECTURE". If your PC has a 32-bit processor, this variable will have a value of "x86". If it has a 64-bit processor this variable will have a value of "x64".
Computers & Internet Logo
Some of my desktop icons have grown to be very big. I want small icons.
in windows 7 right click on the desktop and select Personalize. Then click display on the left. Choose small, medium or large.
in windows xp;
Shrinking Icons in Windows XP
  • 1 Right-click on the desktopicon1.png. A drop-down menu will appear on which you will click on "Properties."
  • 2 In the "Display Properties" box, click on the "Settings" tab.
  • 3 Slide the scale in the "Screen Resolution" box to the right to shrink the icons (and everything else that appears on the screen).
  • 4 Click on "Apply" and then click on "OK."
  • 5 Click on "Start" and then right-click on an empty space until a box that says "Properties" appears. Click on "Properties."
  • 6 In the "Taskbar and Start Menuicon1.png Properties" menu, click on "Customize."
  • 7 In the box that says "Select an icon size for programs," click on "Small Icons."
  • 8 Click on "Apply" and then click on "OK" to adjust the size.
Shrinking Icons in Windows Vista
  • 9 Right-click on the desktop. When the drop-down menu appears, run the mouse-pointer over "View" and click on "Classic Icons." This will shrink the icons if they are set to either "Large Icons" or "Medium Icons."
  • 10 Right-click on the desktop again and click on "Personalize."
  • 11 On the "Personalize appearance and sounds" screen, click on "Taskbar and Start Menu" on the left side bar.
  • 12 In the "Taskbar and Start Menu Properties" menu, click on the "Start Menu" tab.
  • 13 Click on "Customize."
  • 14 Find the box that says "Use large icons." If it is checked, uncheck it and click on "OK." This will shrink the Start Menu and Taskbar icons.
Read more: http://www.ehow.com/how_4855250_make-windows-icons-smaller.html#ixzz2ifeSGGtj
Sep 08, 2013 | Computers & Internet
Configure Wireless Zero Configuration to configure wireless connection on XP computer
I get "no Wireless networks were found in range" when the laptop is sitting beside the router, and the tray icon tells me that "Wireless netyworks detected" . Clicking the tooltip takes me to the "Choose a wireless network" screen, but still "no Wireless networks were found in range".... WTF?
Mar 18, 2010 | Computers & Internet
how to check weather computer will support 64 bit
Feb 10, 2010 | HP RT810UTABA - HP dc7700 small form...
We installed the netgear cd and USB wireless key on a desktop and the internet works fine until you shut down the machine. To make it work the wireless manager needs to be installed all over again - each time you turn it on!
Follow the step below to configure settings:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply.
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab.
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight thee SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
Sep 03, 2009 | Computers & Internet
104 people viewed this tip
David Payne
David Payne
