Tip & How-To about Computers & Internet
Have a problem connecting a new computer to your network? This is kinda easy to do, first find a computer thats already connected to the network, then go to the settings of the network and write down all the information about the network like the wep key, dns server, and even the ip address. Then go the the new computer and go to the settings and fill in everything you wrote down, UNTIL the ip address, this is where it get a little confusing. write down the copied ip address but change the very last number to one number higher that it for example: connected computer ip address: 192.180.1.900* Then here is the ip address you will place on the new computer: 192.180.1.901* then your computer should connect.*=made up number do not use it
Computers & Internet Logo
I have a Toshiba A105-S101; just had to reinstall XP Pro on this laptop.. my internet is hooked up to my desktop and I need this laptop to connect to my wireless internet. What can I do to get it, Im guessing it isn't already on here. I checked and saw that its not under my network connections. I dont know much about computers. Any help?
Good day.
Since you already have a wireless connection, it would be easy for you to connect to the wireless network as long as you know your Network name(SSID) and wireless key which could be WEP or WPA. On the lower right hand on part on your desktop,also called the system tray,please look for the wireless icon which looks like an antenna with radio waves. Right click on that icon and please click "View available wireless connection," your network should appear on the list. Please click on your network name and click "Connect" to start your wireless connection. If it prompts for a wireless key or password, you could contact your Internet Service Provider to provide you with the password.
I hope this has helped you today.
May 12, 2011 | Computers & Internet
I have bought a new laptop and are not able to connect to the internet
The wireless router makes computers that already have an internet connection share signal with another computer. For example, the new computer would still not have an internet connectin. Power on each devices of computer and routers to make the next process achievable. For example, the router searches to acquire any available networks either as locall to internetworked diaplayable on the wireless area logo on the computer settings. Once recognised, local or network signals require request to below as new computer device setup. Usually another computer entity has to be notified of intent to capture signals with new ware. Contacting a wireless network provider guarantees the signals connectivity amongs several resources that makes an experince between devices achieveble. Locate either telephone network establishments to ascertain the requriements to establsihing a new network of devices. Prior to contact the network establishment, ascertain the computer devices brand, pertinent details that would make estabsihement effective.
Feb 14, 2011 | Belkin (54G F5D7230UK4) Wireless Router
how to install an wirless adapter to mi desktop
Install a wireless network adapterIn areas that are served by a wireless network, you can connect to a computer network without using a cable, and surf the Internet or connect with other computers. To connect to a wireless network, your computer needs a wireless network adapter.
Many new computers-especially laptops-come with wireless adapters. Before using your computer, check to see if it already has a wireless network adapter.
If your computer doesn't have a wireless network adapter, you can install one.
Install a wireless USB network adapter. Most people prefer this type of adapter for any type of computer, because it's easy to install.
Install a wireless CardBus or CF network adapter. For portable computers, this type of adapter (also called a PCMCIA or PC Card) is easier to travel with than a USB adapter, because it is often smaller and fits securely in the PC Card slot on the side of the computer.
Install a wireless internal network adapter. If you have a desktop computer, you may prefer an internal adapter so that you can use the USB port to connect another accessory.
The type of adapter you install depends on your computer and your level of expertise.
How to determine if you already have a wireless network adapterMany portable computers manufactured after 2000 have wireless networking built in. However, because the antenna is hidden inside the computer, it's not easy to see.
To see which network adapters are currently installed in your computer
1.
Click Start, and then click Control Panel.
69010-click-control-panel.gif 2.
Click Network and Internet Connections.
69010-click-network-and-internet-connections.gif 3.
Under or pick a Control Panel icon, click Network Connections.
69010-click-network-connections.gif 4.
Microsoft Windows XP displays your network adapters. Wireless network adapters are labeled Wireless Network Connection. If an adapter displays a red X, it is disconnected. If the Network Connections window is blank, your computer doesn't yet have a wired or wireless network adapter.
Nov 12, 2010 | Computers & Internet
i bought a new computer and i need a new software
you dont need to get a new software for connecting the computer to the 2wire, if you already have a computer that is currently connected, the next computer will be plug and play if connected with a ethernet, for wireless you just need to reconfigure the computer for wireless connection
Mar 06, 2010 | 2wire (1000-100052-000) 802.11g/b Wireless...
136 people viewed this tip
David Payne
David Payne
