Tip & How-To about Home
Light bulb stuck
Everyone has heard of the tip for removing a light bulb that seperates from the base while trying to remove it.
Would'nt it be easier if you could keep the bulb from sticking in the first place.
Get a spray can of WD-40 and the next time you change a bulb spray a small about on the bulbs base and wipe with a paper towel so a thin film remains. I've been doing this for years and contrary to what you might think it does not cause a short circuit.
You'll find this most useful in areas with high humidity like a bathroom.
Home Logo
My check engine light bulb does'nt come on
Maybe previous owner removed the bulb...
Sep 29, 2012 | 2003 Nissan Sentra
need to replace light bulb - old bulb broke out but metal part still there
Turn off the power.
There are two base types; screw in and bayonet.
With needle nose pliers try to get hold of the metal base.
If it will not turn (left for loose; right for tight), then it may be the bayonet type base: press in, turn and pull out.
Berninas usually come with a bulb remover. It is a plastic tube about 2" long that everyone wonders..what the heck is this.
Mar 10, 2010 | Bernina Sewing Machines
changing light bulb in a 25 year old freezer
Whatever you do, you MUST unplug the freezer before attempting any repairs... there will not be any release buttons, nor any special installations for water safety... also, take care to avoid cutting yourself on the broken glass..
1) did the whole light bulb glass And internals come out, or is the internal part of the bulb still present?
2) verify that the light bulb is really a screw-in appliance bulb -- look into the center of the broken bulb and see if the metal base has internal ridges -- or if the metal base is smooth on the inside...
3)  if a screw-in appliance bulb:  3a)  if the whole light bulb glass AND internals came out, you will have to probably look very close inside the socket to determine the wall of light bulb base... it should be very thin and flexible and very unlikely you can unscrew it directly -- I've had to take needle-nosed pliers and gently bend and twist until the bulb base came out...
3b)  if part of the glass remains as well as the internal stem, I have heard that one could cut a potato in half and then push the internal part of the potato onto the broken end of the bulb and gently unscrew the bulb by twisting the potato... never tried this so I don't know if it will work -- if the internal stem is still intact, I'd use my fingers and try to gently turn it to unscrew the bulb
4) if it has smooth inside wall -- this is probably a bulb with small exterior pins -- the base should be a little more thicker than the screw-in type, so you should be able to push the bulb base in -- a little give in the spring holding it in -- if you feel this give, then turn carefully counterclockwise and it should pop out...
Again, turn off all electrical power to the freezer, Pull the Plug before attempting any repairs... remove all glass and handle with care...
Jul 25, 2008 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Refrigerator light whirlpool designerstyle
well there is no magic button to push or anything like that some times they get stuck in those plastic holders get a pair of work golves or heavy towel and unplug the unit then just twist it out if the bulb seperates from the base get a pair of needle nose plires and grab it by the base and twist it out
May 21, 2008 | Refrigerators
Ceiling fan lights do not work
You may have shorted out the light kit. Did you remove the other bulbs and put in new ones? They may have all blown when you heard the noise. Try that first, and if it still doesn't work, you may have to buy a new light kit. They are not expensive, and you can buy one without the glass bulb holders or cans, whatever you have. Then you can still use yours after you install the new light kit. Good luck!
Jan 05, 2008 | Hampton Bay 24002 Ceiling Fan
309 people viewed this tip
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
