Tip & How-To about Computers & Internet
Notebook Keyboard Doesn't Work
Try attaching an external keyboard, either via a standard keyboard port (usually called a PS/2 port) or via USB. If this works, the internal keyboard may be defective or have a bad connection. Try removing and reinstalling the internal keyboard; if that doesn't work, replace it.
Depending on the laptop model in question, removing the keyboard can be simple or more complex. In some cases, the keyboard can be lifted free of the system by removing a couple of screws on the bottom of the case to enable the top of the bezel around the keyboard to be removed; on some systems with a snap-apart case, you release the bezel with a flat-bladed screwdriver or special case-removal tool. With other models, additional steps might be necessary.
To determine which steps are necessary, check the notebook computer vendor's Web site for repair (subsystem tear-down and replacement) documentation. I like to use the Google search engine's site-specific search feature.
Be very careful when you work with the integrated keyboard. A fragile ribbon cable is often used to connect the keyboard to the motherboard; if this cable is loose or damaged, the keyboard will malfunction.
Have a nice repair !!!
Computers & Internet Logo
when i start computer the screen stays black and it beeps
Perhaps you've built a computer and are turning it on for the first time, or you've owned this computer for awhile.
Either way, you may encounter an issue where the monitor shows a black screen and the computer is beeping.
There are several causes and solutions for this problem.
Refer to your motherboard manual, since the motherboard is the beeping device.
These beeps are like Morse code, and each "beep code" is explained in the manual.
Common beep codes include not having a monitor or keyboard properly connected; not having a CPU fan connected, or not attaching internal power cables to the video card.
This black-screen-and-beeping issue is most common with newly-assembled computers.
Check external cables to make sure they're properly connected.
The most important external connections to check are the monitor's signal cable and the keyboard.
If your monitor cable looks damaged or kinked, try replacing it with a spare. If your keyboard's cable looks frayed, try a spare keyboard.
Also, a PS/2 keyboard plug (round, with holes in it, about the diameter of a finger) is often color-coded purple.
If you have plugged it into the green port in the back of the computer (for PS/2 mice) switch it to the other one.
If there is no color coding, the proper port should have a small, embossed icon of a keyboard on the back of the computer.
If it does not, refer to your motherboard manual for the correct port.
If all else fails, try a spare keyboard, preferably USB (Universal Serial Bus), which can be plugged into any USB port on the back of the computer.
Check for additional motherboard power connections.
Yours may require multiple cables attached from the power supply.
There is the standard wide plug, which you know is connected properly because your motherboard is beeping.
However, there may also be an additional, four-pin cable that connects elsewhere on the motherboard. Check the board's manual to make sure it has all the power connections it needs.
Check your internal cables.
Make sure that the CPU fan is plugged into the motherboard header nearby.
Without that, the CPU fan will not spin, and the motherboard may detect this lack of connection and produce a beep code.
Your video card also may have one or two internal power plugs that need to be attached to the power supply's cables.
These cables have unique ends on them, similar in shape to a USB plug.
Refer to the case or video card documentation if need be.
If those cables are not attached, your motherboard may refuse to boot the system.
Your video card may be faulty.
If this is a new card, it may have arrived to you broken, in which case you will probably need to request an RMA (Return to Manufacturer Authorization) to receive a replacement.
If this card was previously working for you in this system, you can contact its manufacturer yourself to receive a replacement, if the device is still under warranty.
Hope this helps
Nov 03, 2012 | Dell Computers & Internet
3 beeps at startup no video
The beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
make sure that your RAM modules and Cmos battery are securely seated
on some motherboards Cmos batteries are soldered in
If it does not, refer to your motherboard manual for the correct port. If all else fails, try a spare keyboard, preferably USB (Universal Serial Bus), which can be plugged into any USB port on the back of the computer.
Hope this helps
Oct 28, 2012 | Seagate Barracuda ATA IV (ST340016A) 40 GB...
3 beeps at Startup no video
Hope this helps
Oct 28, 2012 | Computers & Internet
computer has alarm sound when turned on and screen is black
  • INSTRUCTIONS :-
  • 1
    Refer to your motherboard manual, since the motherboard is the beeping device. These beeps are like Morse code, and each "beep code" is explained in the manual. Common beep codes include not having a monitor or keyboard properly connected; not having a CPU fan connected, or not attaching internal power cables to the video card. This black-screen-and-beeping issue is most common with newly-assembled computers.
  • 2
    Check external cables to make sure they're properly connected. The most important external connections to check are the monitor's signal cable and the keyboard. If your monitor cable looks damaged or kinked, try replacing it with a spare. If your keyboard's cable looks frayed, try a spare keyboard.
    Also, a PS/2 keyboard plug (round, with holes in it, about the diameter of a finger) is often color-coded purple. If you have plugged it into the green port in the back of the computer (for PS/2 mice) switch it to the other one. If there is no color coding, the proper port should have a small, embossed icon of a keyboard on the back of the computer. If it does not, refer to your motherboard manual for the correct port. If all else fails, try a spare keyboard, preferably USB (Universal Serial Bus), which can be plugged into any USB port on the back of the computer.
    • 3
      Check for additional motherboard power connections. Yours may require multiple cables attached from the power supply. There is the standard wide plug, which you know is connected properly because your motherboard is beeping. However, there may also be an additional, four-pin cable that connects elsewhere on the motherboard. Check the board's manual to make sure it has all the power connections it needs.
    • 4
      Check your internal cables. Make sure that the CPU fan is plugged into the motherboard header nearby. Without that, the CPU fan will not spin, and the motherboard may detect this lack of connection and produce a beep code. Your video card also may have one or two internal power plugs that need to be attached to the power supply's cables. These cables have unique ends on them, similar in shape to a USB plug. Refer to the case or video card documentation if need be. If those cables are not attached, your motherboard may refuse to boot the system.
      Your video card may be faulty. If this is a new card, it may have arrived to you broken, in which case you will probably need to request an RMA (Return to Manufacturer Authorization) to receive a replacement. If this card was previously working for you in this system, you can contact its manufacturer yourself to receive a replacement, if the device is still under
    • Jul 21, 2012 | Systemax Venture Computers & Internet
      Mouse Doesn't Work in PS/2 port
      CHECK BIOS TO MAKE SURE IT DID NOT TURN ITSELF OFF WHEN YOU PLUGGED IT INTO THE USB.BIOS MAY HAVE TURNED IT OFF TO PREVENT A CONFLICT.RICHARDM69
      Dec 07, 2008 | Foxconn 6100K8MA-RS Motherboard
      325 people viewed this tip
      David Payne
      David Payne
