Tip & How-To about Philips DivX DVD Player
Standalone DVD player with DivX why does the VBR encoded Audio lag the Video
DivX or XVid encoded MP4 Video codec or AVI will almost always have either the Dolby Digital AC3 Codec or the MP3 encoded audio codec see the following links; Fraunhofer MP3 Decoder or LAME MP3 Encoder
This fixed audio lag can sometimes be caused by VBR audio encoded files and starts part way through the playback as opposed to CBR audio some standalone DVD players will exhibit sound lag in this case. It is a good idea to re-encode the VBR to CBR audio this usually solves the problem.
I suggest that you convert/encode all your DivX AVI files into CBR audio to avoid any such errors; all commercial DVD Video Audio is encoded in CBR (constant bitrate) which also reduces the audio filesize unless its encoded in LCPM which will give a much larger audio component.
Check the audio bitrate type open the AVI in GSpot the example below shows an AC3 audio already in CBR so can be left alone and should work fine.
MANUAL CONVERSION PROCESS
This audio MP3 conversion process it a bit of a long way around I know, but it does work!
  • Open video in VirtualDubMod or VirtualDubMP3 (if there is an index error this can sometimes fix it for you.
  • Ignore the error warning that the video contains VBR audio.
  • Extract audio as MP3 ("demux" in VirutaldubMod or save as WAV, then rename to MP3 in VirtualdubMP3).
  • Convert audio to WAV with CDex
  • Open original video in VirtualDub,choose "direct stream copy" for video and "WAV audio" with "Full audio processing" with CBR MP3 compression (and interleaving with appropriate delay if out of sync) for audio.
SEMI-AUTOMATED CONVERSION PROCESS
You could also use several other easier methods including AVIDemux which uses VirtualDubMod or scan in the DVD-Video using TMPEnc v4.0 Xpress and applying a time lead OR lag however this does not solve a progressive lag *** but can be used to re-author a fixed audio lag error in milliseconds you can use either Windows Media Player Classic or KVM Player in real-time to find this lag or lead error and then adjust accordingly
If you can't work AVIDemux then AVIrecomp will be your best solution this is a bit more user friendly
NOTE> always keep a Backup copy of the AVI before you make any drastic changes as you could make the file unplayable the above process will only work on FIXED AUDIO LAG AVI files.
Progressive Audio Lag (starts in synch and runs fast or slow throughout the AVI is almost impossible to remove with re-encoding the AVI using the above methods.
*** Feel free to comment if you know of a foolproof way other than performing a full re-encode from the MPG2 or DVD VOB file.
Televison & Video Logo
what formats does it play for movies?
The Iomega 1TB ScreenPlay MX HD can play these formats in upto 1080i:
Audio:
MP3
AC3 (Dolby Digital Encoding)
WAV
WMA
Video:
MPEG-1
MPEG-2 (AVI/VOB)
MPEG-4 (AVI/DivX 3.11, 4.x, 5.x, 6.x/XViD)
Regards,
Chris
Jul 05, 2011 | Iomega 1TB ScreenPlay MX HD Media Player...
Successful VBR audio conversion for AVI's with Standalone DVD DivX Players
YOU MUST NOT MISS IT!!! -----------http://www.2kuu.com --------- The website wholesale for many kinds of fashion shoes, like the nike,jordan,prada, also including the jeans,shirts,bags,hat and the decorations. All thepr oducts are free shipping, and the the price is competitive, and also can accept the pay pal payment.,after the payment, can ship within short time. free shipping accept the pay pal SOCCER JERSEY 16 nike sh ox $35 Christan Audigier bikini $16 Air jordan(1-24)shoes $36 Sunglasses Oakey,coach,gucci $12 Handbags(Coach gucci juicy lv) $31 Tshirts (,ed hardy,lacoste) $16 Jean(True Religion,ed hardy,coogi) $30 Bikini (Ed hardy,) $18 -----http://www.2kuu.com -------
Feb 26, 2010 | Philips DivX DVD Player
want to creat good quality avi videos for my mp3 player
Looking at the specs, this is a pretty nice player and appears to play multiple mpeg4 formats (divx, xvid h264). I'm not positive it can support all codecs, but, since the player doesn't specify, we should start with the assumption that it can.
The unit comes with encoder software and I've used it before, but, have never been impressed with the capabilities or flexibility of the encoder. I'm going to start you off with a very flexible encoder / editing program. With this, and once you know the basics, you can experiment with multiple settings. But first, you need to download a few codecs and install them to your computer. Before you go any further, download these 3 programs and install.
xvid codec: http://www.xvidmovies.com/codec/
divx codec: http://www.divxmovies.com/codec/
VDubMod: http://sourceforge.net/project/showfiles.php?group_id=65889&package_id=63653&release_id=352709
May 07, 2009 | Philips GoGear SA5245/37 Digital Media...
Audio codec upgrade for DiVX Playing
You need to get the latest AC3 (Dolby codec).
Jan 14, 2009 | Audio Players & Recorders
2,298 people viewed this tip
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
