Tip & How-To about Computers & Internet
How to troubleshoot a dead laptop and find the problem
We may offen face the same problem :when our laptop is dead. In this post I’ll explain how to troubleshoot a dead laptop and find the problem. The following troubleshooting tips are not model and brand specific, they should work for most laptops.
Let’s take a look at two different scenarios.
Example 1. The laptop is absolutely dead.
When you plug in the power adapter and press on the power button, there is no signs of life at all. The laptop will not make usual noises, LED will not light up, the fan will not spin, the screen is blank and black, etc… In short, the laptop is dead.
What you can do in this case?
1. Make sure the wall outlet is working and the laptop DC adapter is getting power from the outlet. Try another wall outlet.
2. Test the laptop DC power adapter, make sure the voltage output is correct. You can test the DC power adapter with a voltmeter.
3. Let’s say the DC adapter is fine and the adapter outputs correct voltage. In this case unplug the power adapter from the laptop, remove the battery, wait for 1-2 minutes, plug in the adapter and try turning on the laptop again.
OK, you tested the adapter and it’s bad. If you decide to replace the original DC adapter with a generic one, you’ll have to follow this rule:
The voltage output on your new adapter has to be exactly the same as on the original adapter. The amperage on the new adapter could be the same or higher.
If nothing helps and the laptop is still dead, apparently the motherboard is fried or there is a problem with the DC power jack. It’s possible the DC power jack is broken and the motherboard is not getting any power from the adapter. In this case you’ll have to disassemble the laptop and replace the power jack. Check out this guide for fixing laptop power jack.
Example 2. When you plug the DC power adapter and press on the power button, the laptop starts making normal noises, the LEDs work properly but noting appears on the screen. The laptop will not start.
First of all, take a closer look at the LCD screen. Look at the screen under bright light. It’s possible that the image is still on the screen but it’s very faint. If that’s the case, check out these tips for troubleshooting laptop with backlight failure.
If there is no image on the laptop LCD screen, test the laptop with an external monitor. Connect an external monitor to the VGA port on your laptop and turn the laptop on. You can toggle video output between the internal LCD screen and external monitor by pressing Fn and F4 keys simultaneously on HP laptops, Fn and F5 keys on Toshiba laptops, Fn and F7 keys on IBM laptops. Other laptops may use different key combinations.
Let’s say the external monitor works fine but the internal LCD screen has no image at all. If that’s the case, your problem could be related to the LCD screen or the video cable. Also, make sure the video cable makes good connection with the motherboard and the LCD screen. Try reconnecting, reseating the cable.
In my case, both internal and external monitors were absolutely dead. Neither of them had image. That means the problem is not related to the LCD screen or the video cable. From my experience I know that this problem could be related to the laptop memory.
Try reseating the memory module, maybe it’s not making good connection with the memory slot. Try cleaning contacts on the memory module with pen eraser. Try moving the memory module into another slot. Try replacing the memory module with another known good module, it’s possible that your original module is dead.
If you have two memory modules installed you can try removing them one by one, it’s possible that one of the modules is bad. Try installing different memory modules into different memory slots.
In my case reseating, swapping the memory module didn’t help. I was pretty confident that my problem is not memory related and I moved on.
Try removing battery, hard drive and DVD drive and turning on the laptop without these components.
Also, try turning on the laptop with an external monitor when the video cable is unplugged from the motherboard. If the laptop start with video on the external monitor, apparently there is something wrong with the laptop display panel.
In my case removing the hard drive and DVD drive didn’t help. Unplugging the video cable didn’t help either.
I continued taking my laptop apart piece by piece and tested it after each step.
I removed wireless card, modem, disconnected the keyboard but it didn’t help.
I still wasn’t able to boot the laptop with video on the external monitor.
Finally, I disassembled the laptop and removed the motherboard.
On this picture you see my final test. The motherboard has been removed from the base and I assembled basic barebone system on my bench.
1. Motherboard. Like on most laptops, in my case the video card is integrated into the motherboard
2. CPU with heatsink and cooling fan.
3. Known good memory module.
4. The power button board witch I need to turn on the system.
5. Working DC power adapter.
Still cannot get any video on the external monitor. The system turns on, the cooling fan starts spinning but there is no video.
At this point I’m 95% sure that the motherboard is dead. CPU failures are not very common, so it must be bad motherboard. may be this arcitle is good for you.thank you for reading.
see more information from http://udtekbattery.wordpress.com
Computers & Internet Logo
sony kv-f29mf1 is dead fuse blows offenly
Service manual has been send to you.
Check this site for more details. It has more than 1400 posts to different brands of electronic entertainment and other equipments. All posts referrers with the repair and fault finding to electronic entertainment equipments. It will be best to view it either in Flipcard or Timeslide option, can be selected by the sidebar tag at the top left of the display screen. Timeslide view will be the best to select. If you are using Google Chrome as browser, Flipcard option will be the best.
Dec 08, 2012 | Televison & Video
The router is connecting me with an unknown network
your router is not connecting you to a different network.it`s your laptop which is connecting automatically to a preferred network or you can say it is connecting to whichever unsecured network is available.please clear ypur preferred network list or you`ll keep facing the same problem.i can`t explain you how you can do that because you have not mentioned the OS you are using.please use google for the same.thankyou
Jul 16, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Dead Toshiba A100 laptop computer
In order to replace the power jack in your laptop you’ll have to remove the jack from the motherboard as I explained in the previous post: Replacing DC power jack.
While removing the jack you can accidentally pull out the internal copper coating (I’ll call it a sleeve) from the inside of the “+” terminal as it shown on the picture below.
The internal copper sleeve has been removed and cannot be installed back. If you solder the power jack back on the motherboard without this sleeve it might work but the connection between the “+” lead and motherboard will not be reliable.
In the following guide I explain how to fortify a damaged power jack connection. You can use this repair technique in some laptops with similar power jacks.
Laptop is dead. How to troubleshoot the problem.In this post I’ll explain how to troubleshoot a dead laptop and find the problem. The following troubleshooting tips are not model and brand specific, they should work for most laptops.
When you plug in the power adapter and press on the power button, there is no signs of life at all. The laptop will not make usual noises, LEDs will not light up, the fan will not spin, the screen is blank and black, etc… In short, the laptop is dead.
If nothing helps and the laptop is still dead, apparently the motherboard is fried or there is a problem with the DC power jack. It’s possible the DC power jack is broken and the motherboard is not getting any power from the adapter. In this case you’ll have to disassemble the laptop and replace the power jack. Check out thisguide for fixing laptop power jack.
Jan 12, 2009 | Computers & Internet
Dell Inspiron 9200 stopped working does not power on
This is a very useful post from LapTopReapir-101
Laptop is DEAD. How do your troubleshoot the problem?
What you can do in this case?...
For more in this article please click on the link below.
if you have other questions just lemme know
Sep 19, 2008 | Dell Inspiron 9200 Notebook
276 people viewed this tip
David Payne
David Payne
