Tip & How-To about Apple iPhone Smartphone
Tips and Hints on How to Maximise You iPhone 3GS Battery Life
1. Turn Screen Brightness down to less than a half and turn on Auto Brightness. (Settings - Brightness).
2. Turn off Location Services when you are not using a GPS dependant App. If on a long journey using the iPhone's GPS, only turn the App and the service on every so often. GPS based Apps really eat battery life up!
(Settings - General - Location Services - Off).
3. Turn off Fetch Data. With this feature enabled the iPhone will interrogate the internet or your mail account every so often to fetch data, for example, an e-mail. This drains battery life. (Settings - Mail Contacts - Calendars - Fetch New Data - Push Off).
Or if you really want to keep this feature, just follow the same protocol as above , but instead of switching "Push" off, below that, adjust Fetch Data settings, to fetch on a less regular basis ie Hourly as opposed to every 15 mins.
4. On long journeys when all you need is the iPod functionality, turn Flight Mode on.
(Settings - Airplane Mode Off).
5. Remember to run the battery completely flat every so often. I do it around once a month and then fully charge it again.
6. Turn Bluetooth off.
(Settings - General - Bluetooth Off).
7. For those of us who have an iPhone 3GS or updated software on iPhone, switch on the Battery Percentage for better battery monitoring. (Settings - General - Usage - Battery Percentage On).
8. If you are fairly desperate for battery you can turn off the 3G feature of the iPhone. 3G enables higher browsing speed and better call quality. (Settings - General - Network - Enable 3G Off).
9. Turn Wi-Fi off if not in use. The iPhone will use battery searching constantly for Wi-Fi networks. (Settings - Wi-Fi - Wi-Fi Off).
10. Remember, if you really can't manage with the battery life, you can buy iPhone cases which provide extra battery power.
Good Luck
Apple iPhone Smartphone Logo
What is causing my Samsung s5 to overheat while charging
1. Screen Brightness (auto best)
2. Location Services
3. If your aren't using it turn off wifi
4. Turn on power saving mode
6. Make sure bluetooth is off
7. Close all apps
8. If needed try shutting down phone while charging
Jun 03, 2016 | Samsung Cell Phones
Apple iPhone Battery Saving Guide The Apple iPhone doesn't have the best battery life in the world but if you follow this simple guide it should provide you with a longer battery life. 1. Turn down the brightness: You can reduce the battery consumption by turning down the brightness of the screen. Select Settings, Brightness, and then drag the slider to around the 25 percent mark, or as low as you can stand. 2. Turn Wi-Fi and Bluetooth off: From the main menu, tap Settings, Wi-Fiand select the "Off" switch. Same goes with Bluetooth; if you're notusing a Bluetooth headset, make sure the Bluetooth radio is deactivated(Settings, General, Bluetooth). 3. Check e-mail less frequently: If you are using Pop Mail then you can save battery by checking it less frequently. Select Settings, Mail, Auto-Check, and pick either the "every 30 minutes" or (better still) "every hour" options. 4. Sync less frequently: If you sync with an Exchange server either turn it to manual or set it only to check periodically 5. Make sure "Auto-Lock" is on: TheiPhone will keep its bright screen burning unless you manually pressthe lock/sleep control. If you haven't already, make sure the iPhone's"Auto-Lock" feature is on: tap Settings, General, Auto-Lock, and then pick a time interval (the shorter the better). 6. Turn off the equalizer: Apple has always suggested turning off the iPhone?s built-in equalizer to conserve battery life. Tap Settings, iPod, Equalizer, then spin the roulette wheel up to Off.
Dec 23, 2009 | Cell Phones
Why is my Samsung s5 overheating
3. If you don't need it turn off wifi
7. Close all apps except the one your using
8. Use apps that can disable autostarting apps
increase battery life in iPhone4s
turn on auto brightness, reduse sreen brightness,turn off bluetooth when not in use,turn 3g/4g or lte,keep wifi off when not in use ,turn off location services,turn data push off,fetch email less often,turn auto lock to a sooner time ( like 3 minutes or 4),turn off equilizer/EQ)
Feb 24, 2013 | Apple iPhone 4S
926 people viewed this tip
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
