Tip & How-To about Computers & Internet
Black and white or negative screen resolution in Mac OS X
A black and white display, or negative screen resolution, is an issue which can occur within the various Mac OS X system versions ranging from Mac OS X 10.3 to Mac OS X 10.6.
It can appear as an anomaly which can leave a Mac User dumbfounded, not sure what is going on.
At one time your screen is normal like this, but then somehow,
the screen changes into this strange negative, inverted screen.
So how does this occur?
The answer is more simple than you think.
An inverted screen like the one you see in the screen shot above, is not actually an anomaly, or the result of some sudden strange happenstance. What's more, chances are, this occurred because of what you did.
Its an easy fix however, because the only way your Mac OS X desktop screen can turn into a negative or black and white resolution, from its normal color resolution, is if a setting within your Mac OS X system has been modified.
To return your screen back to the normal color resolution, follow these steps:
* Click on the Apple menu icon, located on the upper left corner of your Mac OS X desktop screen.
* From the drop down menu, select System Preferences.
* Within System Preferences, select the pane (in System Preferences, Apple references all icons as "panes") entitled "Universal Access".
Quick Note About Universal Access:
The reason this System Preferences pane is known as"Universal Access", is due to the purposes Apple designed it for. If you notice the image for this pane above, this symbol for this feature, is similar to a placard or sign you would see on a car license plate, parking space, door or building, for an individual who has a disability or is handicapped.
Universal Access was designed to enhance features like Voice-over speech (your Mac talks to you), screen size, display settings, keyboard and mouse settings for those Mac users who are vision impaired, hearing impaired and /or physically disabled.
* For the next steps in the process:
Click on the Universal Access pane.
If you look in the screen shot, under Display, you will see that the current setting is "White on Black".
Click on the radio button entitled "Black on White"
and this is the window you will see:
Back to normal!
That is all it takes, to return your desktop screen resolution back to normal.
This is why you were suggested as the probable cause" for your desktop screen to go into Inverted mode. Chances are you may have been in System Preferences, clicked on the Universal Access pane, and in exploring settings, may have clicked the Display setting and the
White on Black radio button, causing the screen to go into
the inverted mode or change in gray scale.
Another theory could be that you may have accidentally pressed the Ctrl-Alt-Apple Command keys on your keyboard, combined with either < > keys, depending on if you were in process of' increasing or decreasing contrast on your Mac's screen or display.
The true purpose of the inverted screen mode or change in gray scale, is to aid Mac Users who may be sensitive to the bright normal colors, that you and I see on the standard Mac OS X display screen, due to poor or failing vision.
So now that your screen is back to normal, if you should see an inverted display, or screen that resembles a negative resolution, like that of a photo negative, you know how to correct this issue.
For more information on Universal Access, click here.
Regards,
- Mactechtrainer
Computers & Internet Logo
my screen is white
Sony Vaio is one of the most prominent brands of laptops on the market, and also one of the most expensive. The laptops, created by Sony, are known for their efficient processor functionality and sleek designs. While the Sony Vaio line of laptops are considered high-end, they are also prone to display problems.
Symptoms
Among the problems facing Sony Vaio laptop screens are blackouts. When these blackouts occur, the monitor turns solid black, and upon rebooting the laptop, light will briefly flash on only to blackout again. Additionally, there have been reports of an issue which causes the screen to flicker intermittently until it goes out all together. b> Troubleshooting b> Blackout displays and the continuous flickering of Sony Vaio screens can be caused by various issues taking place inside the laptop. It is not necessarily true that the problem lies within the LCD screen itself, with display issues often occurring as a result of problems with other parts of the laptop. You can test whether or not the screen is defective by connecting the laptop to an external monitor. If the display comes up normally, then the problem lies within the laptop's LCD screen. b> Parts b> If your Sony Vaio is connected to an external monitor and suddenly goes black, then the problem may have to do with the laptop's sleep button. The sleep button latch located inside the device may be jammed or broken, thus putting the screen in a permanent sleep mode until the latch is fixed. Encountering hissing sounds when the laptop is running indicates a faulty circuit board, usually damaged due to overheating. Display issues can also occur when certain parts of the laptop, such as the hard drive, have been replaced. b> Design b> Some owners have made complaints about Sony Vaio design flaws, specifically mentioning defects in the laptop's boards. Among the problems discovered after opening the laptop include burnt LCD fuses, as well as worn out circuits and internal latches. Some of these events may occur even in newly purchased units. Sony has not yet responded to various consumer complaints and has not yet issued any recalls in response to reported problems. b> Repair b> When repairing a defective Sony Vaio laptop screen, it is important that owners remain aware of the nine screws which hold the laptop cover and the board together. Not doing so can easily lead to further damage to the Vaio due to static electricity, and may even lead to a short circuit. For owners who are experienced in the area of laptop repair, parts are readily available for purchase, allowing for cost efficient repair. b> Extended desktop You will need to connect to another monitor or your television to your computer with the vga lead monitor connection. Click start control panel display change display settings adjust resolution this may vary depending on your operating system You should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes. or Click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes if you can get an extended desktop your monitor is faulty if you cant get an exended desktop
Jan 28, 2013 | Sony VAIO VGN-CS204J/W 14.1" Notebook...
My computer has got vertical blacked out strips that are making the screen 18 mm narrower on both sides. Can you help me return my screen back to full size?
Go to
Finder » Applications » System Preferences
In the window that opens, select 'Displays' under Hardware
Here you can select a range of Resolutions, including some that state stretched. You can try a few of these (clicking on them will automatically change the resolution (the screen may go blue for a second in the process)). Most likely, the resolution you have currently selected will have a (stretched) option that may resolve your issue.
Feb 14, 2011 | Apple PowerBook G4 Mac Notebook
Negative screen image
Look in System Preferences for Universal Access, there is a Display option which says Black on White(the normal setting) and White on Black (the setting that has been enabled).
There is a keyboard short cut to change the setting, it involves pressing four keys - Apple, Option, ^ and 8.
Nov 29, 2008 | Apple iBook G3 Mac Notebook
1,784 people viewed this tip
David Payne
David Payne
