Tip & How-To about Computers & Internet
How to copy DVD, rip DVD, convert DVD with Aimersoft DVD Ripper?
This step-by-step guide will show you how to copy DVD, rip DVD,convert DVD with Aimersoft DVD Ripper. This DVD Ripper guide includes 4parts:
Part1. How to convert DVD to iPhone/iPod/PSP/Zune/Apple TV/Phone/PS3/Xbox 360/Zen/Pocket PC/AVI/MPEG/MP4?
Part2. How to edit, combine and crop DVD movies?
Part3. How to extract and rip audio from DVD to MP3 for iPod nano, shuffle and other MP3 players?
Part4. How to put DVD clips on Youtube, Myspace?
What you need is Aimersoft DVD Ripper
Part 1. How to convert DVD to iPhone/iPod/PSP/Zune/Apple TV/Mobile Phone/PS3/Xbox 360/Zen/Pocket PC ?
Step1.Insert your DVD disc into your DVD-Rom, then run the software, click“Load DVD” button and add the DVD file. You can also add DVD/IFO fromyour hard disk by clicking “Load File”.
Step2.This software can convert DVD to various video formats such as MPEG-4,AVI, WMV, FLV, 3GP, VOB, etc. Click the “Format” drop down list toselect a format. If you want to copy DVD to computer in 1:1 lossless quality, please select “Lossless DVD Copy (*.vob)”.
If you don’t know much about mobile players, just select a formataccording to the name of your mobile player. For example, if you wantto copy DVD to the coming iPhone,just select “iPhone Video MPEG-4 (*.mp4)”, and the default settingworks great. If you want to customize the output video, you can clickthe “Settings” button next to the format field to open the Settingswindow and set video resolution, frame rate, bit rate, encoder, etc.See the figure below:
Step3. Select Subtitle and Audio
Regular DVD movies usually have several subtitles such as English,French, German, etc. You can select one you prefer. You can also deletethe subtitle by selecting “No Subtitle”. Selecting Audio is the same.
After the above steps, click “Start” to start conversion.
Part 2. How to edit, combine and crop DVD movie?
Afteryou load the DVD file. If you want to cut the black edges of the DVDmovie, you can click the “Crop” button, and then you will see a pop upwindows (See the figure below). There is a frame in dashed line aroundthe movie video; you can drag it to cut the black edges.
Moreover, you can click the Crop drop-down list to select a Crop model youprefer, for example: “Cut off top and bottom black edges”. You can eventype the number in the box to cut off black border accurately.
If you want to combine several DVDchapters into one file, on the main interface, there is a check box“Merge into one file”, select it, then you will only get one outputfile instead of several files by chapters.
If you want tosnatch pictures from DVD, while you previewing the DVD movie, therewill be a small camera icon below the preview window, click it when youwant to snacth the picture, it supports output picture as JPEG or BMP format.
You can click the “Effect” button and customize the brightness,saturation, contrast, volume, etc (See the figure below). You can evenapply special effects such as “Emboss”, “Negative”, “Old film” and“Gray” by selecting an effect from drop-down list.
Part 3. How to extract and rip audio from DVD to MP3 for iPod nano, shuffle and other MP3 players?
Thissoftware can extract and rip DVD audio track to MP3, WMA, WAV, AC3,AAC, M4A and so on, if you want to rip the music from DVD to your MP3players such as iPod Nano, iPod Shuffle, Creative Zen, Zune and so on.After you load your DVD movie, in the main interface, select the outputformat as MP3, and then start conversion. If you want to get bettermusic quality, you can select a higher audio bit rate and sample ratein the settings window.
After the conversion, drag the audio file to iTunes library, connectyour iPod nano or iPod shuffle to your computer, and click iTunes “File-> Sync iPod”, OK. If you don’t have iTunes, you can download it forfree from Apple official site
http://www.apple.com/itunes/
For PSP, just copy the music to the “Music” folder on your memory stick.
For Zune, drag the music to the Zune software, and click “start sync”.
Part 4. How to put DVD clips on Youtube, Myspace?
This software can convert DVD to FLV format for Youtube, Myspaceand other video download sites. So you can share your own DVD clipswith friends. After your movie is imported, select FLV as the outputvideo format. Then log in Youtube, Myspace upload your video. But awhole DVD movie might be very large. By default, this software willconvert the whole DVD to one file; if you just want several chapters ofthe DVD, you can just select the chapters you want to convert (you canpreview the DVD clip before converting it).
Or you can click “Trim” button to open the trim panel, drag the trimbar to set start time and end time to convert a clip from your movie.You can also type the exact time values in the Set Start Time field andSet End Time field to trim video.
Computers & Internet Logo
How do I burn/copy a DVD
you have to rip the dvd using software like DVDRipper. Then you can burn the resulting file to a 4.5 GB DVD. Usually the movie will be around 7.5 GB and the ripper reduces the size to fit that.
Sep 18, 2009 | Computers & Internet
How do you load a movie on a psp?
Hey!
Usually, the DVD has CSS protection, therefore, you need a DVD Ripping tool to help you remove the protection first and then convert DVD into the PSP supported video. And PSP usually supports MP4 and WMV video. So after converting DVD to MP4 or WMV video, you can enjoy it on your PSP. There are a lot of such DVD ripping software. I recommend you use this Wondershare DVD Ripper Platinum which is very easy to use with only 3 steps. Usually, converting a dvd movies only takes half an hour. You can have a free try of it at: http://www.dvd-ripper-copy.com/dvd-ripper-tools.html#181.
Hope that helps!
Sep 14, 2009 | Sony PlayStation Portable (PSP) Console
I need to know what formats you can record a DVD and which is bes
Hey!
I am now using Wondershare DVD Ripper Platinum which can turn DVDs into almost any video format directly including FLV video you have mentioned. So you can have a try of it and convert your DVD into FLV video directly. You can free download it at it's official web: http://www.dvd-ripper-copy.com/dvd-ripper-platinum.html#181. For how to use it, you can refer the official guide at: http://www.dvd-ripper-copy.com/guide/dvd-ripper-tutorial.html#181.
Hope that helps.
Sep 01, 2009 | JVC SR-MV40 DVD Recorder/VCR
dvds
Get a DVD Ripper:
You can google "DVD ripper" for more selections
Heres one of the top ones:
http://www.dvdtox.com/dvd_ripper.htm
-Cam
Oct 21, 2007 | HP Compaq Presario V2000 Notebook
193 people viewed this tip
David Payne
David Payne
