Tip & How-To about Nintendo DS Lite
DS Lite Top Screen Replacement
Has your top screen devlouped a fault or stopped working altogether? Here is my guide to re-connecting a new top screen and fitting a new one.
Take the DS lite apart (a tri wing screwdriver is needed and can be found cheap on ebay), disconnect the top screen by lifiting the motherboards connector flap (located near the hindge) and then re-insert it, try switching it on again and see if thats sorted it. If not then you will need to replace the screen. (If you need help taking the DS lite apart then check out my other tips and tricks posted on here).
A new screen can be brought on ebay for a reasonable price, there will be a little soldering required as the speakers will need to be de-soldered from the old screen and re-soldered onto the new one (please take note of which wire goes where).
Remove the screws from the lid of the DS lite (4x screws hidden under little coloured squares above and below both speaker outlets) slide the top/outer part away from the hindges, it will move about 5mm and then you can lift it off... Gently pull the ribbon through the hindge so that it is free from the bottom part of the DS lite, pry the screen away from the shell (a small amount of force may be required to remove it) remove the front plastic part of the screen (with the respective DS lite coloured frame, de-solder the speakers, re-attatch them to the new screen, place the new screen into the housing along with the speakers and put back the wifi and mic to their original position if they got moved, you will notice a slot in the hindge where the ribbon goes in, this is for the ribbon to easily slide back into the bottom part of the DS lite... pop the ribbon through and then re-attatch it to the motherboard with the connector, pressing down the connectors flap.
Screw the DS lite back together, after this you will need to place the plastic sheet with the respective DS lite coloured frame back onto the top screen... The reason you don't put it on any time before that is if you put it on prior to putting the new screen in place you will have great difficulty trying to get it correctly aligned.
If you find that your DS lite now doesn't want to stay powered on please refer to my other tips and tricks I have issued on here.
I hope this helps and have to say that I accept no responsability for any damage that may occur to your DS lite when following these tips.
Regards,
SOD69
Nintendo DS Lite Logo
alarm fob stopped working on rover sterling how do i bypass the immobilizer to start the car
inside your key fop were the battery fits there is three soldered points
just check they are connected properly if not just re-solder the connection i had the same fault on my rover 400 and that sorted it. if you are not sure about the connections being soldered correctly fold a small amount of paper and put it on top of your battery holder and refit your fop and then try it that should work just as well.
Sep 03, 2012 | Cars & Trucks
Top drawer stuck, lid lock motor bad and guide bars, if white guides , need to replace with black. Tech said $580 for Fisher Paykel DD603-SS Motors and guides
That's right you will need New Black lid Actuators fitted top and bottom also new retro link supports if you still have the factory plastic ones and maybe a new RFI module if you'd had a F1 fault. Sounds like you've been told this, so now all you need is to get quotes for all these parts to be fitted at a cheaper price. cheers
May 06, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
C200 elegance s reg. wiper sticks or jerks half way across scrn
change motor and fit a new one not a scrapyard one ,check spring tension on arm and try a smaller wiper blade .Keep the receipt for the new motor so you can claim waranty
Mar 08, 2009 | 1998 Mercedes-Benz C-Class
PANASONIC EX3 MINI DV FAULT CODE PLEASE HELP
Hi
I have the same camera and just had a warner F02 code on my screen and the red light flashed twice. I have just taken out my tape and switched off then switched back on and all the functions are working. Hope this helps.
Oct 06, 2008 | Panasonic NV-EX3EN Mini DV Digital...
1,396 people viewed this tip
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
