Tip & How-To about Computers & Internet
Bullet Proof FTP Server Tutorial
This is for the BulletProof FTP Server 2.10. However, It should work fine on most following versions as well.
I'm assuming you have it installed and cracked.
Basics 1. Start the program. 2. Click on Setup > Main > General from the pull-down menu. 3. Enter your server name into the 'Server Name' box. Under Connection set the “Max number of users" to any number. This is the limit as to how many users can be on your sever at any time. 4. Click on the 'options' tab of that same panel (on the side) 5. Look at the bottom, under IP Options. Put a check in the box “Refuse Multiple Connections from the same IP”. This will prevent one person from blocking your FTP to others. 6. Also put a check in the 'Blocked Banned IP (instead of notifying client). VERY IMPORTANT! If somebody decides to 'Hammer' (attempt to login numerous times VERY quickly) your server/computer may CRASH if you don't enable this. 7. Click on the 'advanced' tab 8. At the bottom again look at the 'hammering area' 9. Enable 'anti-hammer' and 'do not reply to people hammering' Set it for the following: Block IP 120 min if 5 connections in 60 sec. You can set this at whatever you want to but that is pretty much a standard Click 'OK'
Adding Users 11. Setup > User accounts form pull-down. 12. Right click in the empty 'User Accounts' area on the right: choose 'Add' 13. Enter account name. (ie: logon name) 14. In the 'Access rights' box right click: choose ‘Add’. 15. Browse until you find the directory (folder) you want to share. In the right column you will see a bunch of checkboxes. Put a check in the following ones: Read, Write, Append, Make, List, and +Subdirs. Press 'select'. 16. Enter a password for your new FTP account. 17. Click on 'Miscellaneous' in the left column. Make sure 'Enable Account' is selected. Enable 'Max Number of Users' set it at a number other than zero. 1 for a personal account and more that one for a group account. Enable 'Max. no. of connects per IP' set it at 1
18. Under 'Files' enable 'show relative path' this is a security issue. A FTP client will now not be able to see the ENTIRE path of the FTP. It will only see the path from the main directory. Hide hidden flies as well. Put a tick in both of these.
Advanced: You don't need to do any of this stuff, but It will help tweak your server and help you maintain order on it. All of the following will be broken down into small little areas that will tell you how to do one thing at a time.
Changing the Port The default port is always 21, but you can change this. Many ISPs will routinely do a scan of its own users to find a ftp server, also when people scan for pubs they may scan your IP, thus finding your ftp server. If you do decide to change it many suggest that you make the port over 10,000. 1. Setup > Main > General 2. In the 'Connection' Area is a setting labeled 'Listen on Port Number:' 3. Make it any number you want. That will be your port number. 4. Click 'OK'
Making an 'Upload Only' or 'Download Only' ftp server. This is for the entire SERVER, not just a user. 1. Setup > Main > Advanced 2. In the advanced window you will have the following options: uploads and downloads, downloads only, and uploads only. By default upload and download will be checked. Change it to whatever you want. 3. Click 'OK’
While you are running your server, usually you will end up spending more time at your computer than you normally do. Don't be afraid to ban IP's. Remember, on your FTP you do as you want.
When you are online you must also select the open server button next to the on-line button which is the on-line Button
You also have to use the actual Numbered ip Address ie: 66.250.216.67
Or even Better yet, get a no-ip.com address
Computers & Internet Logo
i want to create a ftp server in my internet . i create an ftp server by using serve-u but it only open in my lan.i gave my external ip adress but it does not open out side of my lan.plz help to create an ftp server . plz contact with my email navaneet31@yahoo.com.
I use HFS its something called a http file server, its really useful, i use it to transfer files from my pc to my ps3, instructions come with it and its really easy to use
http://www.rejetto.com/hfs/?f=dle
You don't need to install, just run the .exe file, once the window opens just drag the files you want into the window
to access the files from another pc or device just put your specific ip into the addrss bar i.e http://192.68.2.198
Jul 04, 2009 | Microsoft Windows XP Professional SP2 Full...
unable to ftp from outside of the network. Went through all of the port forwarding setup. Still can't connect.
You need to setup a Port Forwarding / Virtual Server (FTP) in the router to forward port 21 (FTP default) to your FTP server's FTP port. You may need to setup a reserved IP address for the FTP server first in the router before the option comes up.
May 27, 2009 | D-Link DIR-625 (790069292637) Wireless...
problem downloading files up to 100 mb
Well, here's a bit complicated, yet effective method that just might reduce your downloading headaches... Let's say you're connect to the Internet using a 28.8K modem and that your Internet service provider lets you telnet to their server. Of course, your provider's server can download files much faster, so the idea here is to download the file to their server at high speed, split it, and retrieve parts at the highest speed you can to your provider's server. Generally speaking, this method not only is a faster way to download files, but it is also a more reliable method since you'll be downloading many smaller files rather than one large file.
First, find out the FTP address of the large (larger than 16M for example) file that you want to download. For example:
ftp://ftp.x.com/bigfile.zip
Telnet to your Internet service provider's server.
telnet x.com
From within the telnet session, download your file to your provider's server. Following is a "screen shout" of a sample file transfer on an UNIX compatible server. Blue/bold text represents your input.
ftp
ftp> open ftp.x.com
Connected to ftp.x.com.
220 ftp x.cpm FTP Service (Version 2.0).
User (ftp.x.com:(none)): anonymous
331 Anonymous access allowed, send identity as
Password: my_address@x.com
ftp> binary
200 Type set to I.
ftp> get bigfile.zip
200 PORT command successful.
150 Opening BINARY mode data connection for bigfile.zip
226 Transfer complete.
ftp> quit
221 Thank you for using x.com! Once the file is download to the server, the next step is to divide the file into smaller pieces so that you will not waste too much time downloading should your Internet dial-up connection go down.
split -b 2000b bigfile.zip
You're almost there! Now simply log off from your telnet session and start downloading (from your provider's server to your computer) smaller files (not the bigfile.zip) which the above split command (on most UNIX compatible machines) created.
Once you have all the files, simply merge them and you got a good copy of the original bigfile.zip. If you're using DOS or Windows, you can merge files using the following command (assuming that bigfile.zip (16000 byte file) was divided into 8 2000 byte files named xaa to xah):
copy /b xaa xab xac xad xae xaf xag xah bigfile.zip
Don't forget to log back into your Internet service provider's computers and delete temporary files (bigfile.zip and xaa..xah) once you've made sure that your downloaded copy is in good condition. Doesn't sound like the above steps could make your downloads faster or more reliable? Well, in most cases it does; specially if the file you're downloading is rather large. The reason why this method could possibly be faster is because you can download files from your provider's computer to your computer faster than from most remote sites. Of course, the reason for reliability is that downloading many smaller files makes it possible to resume a download without wasting as much time as resuming a larger file download would.
************ALTERNATIVELY***********
You can use FRESH DOWNLOAD.Fresh Download is an easy-to-use and very fast download manager software that turbo charges downloading files from the Internet, such as your favorite freeware/shareware, mp3 files, movie files, picture collections, etc. Unlike any other similar utilities, this software is 100% free, no charges, no banners in the software (whichsteal your bandwidth), no spyware.
Apr 13, 2009 | Arris Touchstone 450a (CM450) Modem
Receiving & sending Yahoo!7 emails thru' Outlook Express V.6.00
hi there,
try to do a reset web setting on your internet options.
Mar 22, 2009 | Computers & Internet
Sonicwall Pro 300 DMZ Problem
If you're within a network and try connecting to computers on it with the WAN public IP, it simply won't work - you must use the network IP. On an external Internet connection, it should connect fine to the public IP. If you have access to an external machine (remote desktop), or if you know of an FTP proxy, you can try it that way. I also believe http://www.webftp.co.uk/ a web based FTP client would act as somewhat of a proxy, you could try that with the public IP and see how you go.
Aug 09, 2007 | SonicWALL PRO 300 Firewall
283 people viewed this tip
David Payne
David Payne
