Tip & How-To about Apple iPhone Smartphone
How to make your iphone have a cool backround
1. Open your iphone and go to settings.
2. From there go to General.
3. After General scroll down and you should see a button called Accessibility, click it (if you don't have that update your phone)
4. Then look at the very bottom and click on triple click home.
5. Finally just click White/Black
Then go to your home-screen and triple click! This works with your pictures and apps.
If you don't like this just repeat steps 1-4 and instead of clicking White/Black, click whichever you think you'd like the most.
Apple iPhone Smartphone Logo
how to turn on predictive text on iphone 4s
Hello, the following sequence of tasks should achieve what you are looking for in text prediction as well as other features....
(1) From the Main menu.. Select "Settings"....
(2)Scroll down Settings menu and Select "General".....
(3) Scroll down General menu and Select "Keyboard"....
(4)Turn on all options within the Keyboard menu such as Auto-Capitalization, Auto-Correction, Check Spelling, Enable Caps Lock.....
Save thos selections and that should do the business... Come back to me if these selections do not achieve what you are looking for........Good Luck.....
Mar 07, 2015 | Apple Iphone 4s latest Model - 16gb -...
How to rest a touch screenphone
Step 1:
What kind of phone? iPhones can be reset through the following steps.
Step 2:
Open Settings App
Step 3:
Click into General
Step 4:
Scroll down to Reset, and click it.
Step 5:
Click the appropriate reset button, repeat as needed.
Dec 09, 2012 | Computers & Internet
how to get setting on iphone 4 language?
If you're trying to change the language on your iPhone 4, do this: Go onto your home screen, find the 'Settings' application, scroll down and open 'General', scroll down and open 'International', click 'Language' at the very top, choose the language you want your device to be in and then click done.
Oct 11, 2011 | Apple iPhone 4 Black Smartphone
ipone 3gs restore factory setting code?
How to Restore iPhone 3G to Factory Settings
Make sure you are on the screen that holds your Settings icon. That is the icon with gears pictured in it. Touch the Settings icon.
In the Settings menu, touch the line that says General. It also has a picture of gears.
Scroll down the General page and you will see a line that says Reset. Select Reset.
This screen will show you several options you can reset including setting, home screen, keyboard dictionary, network settings and location warning. However, to erase all data, you will select the line that says Erase All Content and Settings. When you select it, a box will pop up with a red button saying Erase iPhone. There is also a warning saying it will delete all media and data and will take up to an hour. Touch the red button and your iPhone will format itself back to factory settings.
Tips & Warnings
Back up all data you want to save on your computer.
YOU WILL LOSE ALL DATA!!!!!
Also,
To restore iPhone and reset the phone to default factory settings, follow these steps:
1. Turn off iPhone - Hold down the Sleep/Wake button for a few seconds until the red slider appears, then slide the red slider. Ignore this step if your iPhone is already off.
2. Press and hold down the Home button for about 10 seconds until a yellow triangle with a text which says Please Connect to iTunes appears.
iPhone Recovery Mode
3. Plug the iPhone into Mac or Windows PC. Release the button if you haven't.
4. Run and open iTunes if it's not already opened yet.
5. iTunes will prompt a message that says iTunes has detected an iPhone in recovery mode. Click OK.
6. You will be taken to the iPhone pane. Then, click on Restore.
7. Wait for the full restoration process to complete, and the iPhone will be back to the original settings state as when it left the manufacturing factory, typically a working phone again if you face any problem, unless it's hardware related.
There is another mode called DFU mode which does not load the iBoot, and commonly used to downgrade the firmware and restore custom IPSW.
Use the link to below for DFU
mydigitallife.info/2010/10/25/how-to-enter-dfu-mode-in-iphone-ipad-and-ipod-touch-recovery/
Hope it helped.
Thanks for using fixya,..
Jan 15, 2011 | Cell Phones
922 people viewed this tip
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
