Tip & How-To about Computers & Internet
Enable hidden Administrator account Window 7
Try this, 1. Open a elevated command prompt. Click on All Programs and Accessories, then right click on Command Prompt and click on Run as administrator.
2. To Enable the Hidden Built-In Administrator Account -
A) In the elevated command prompt, type net user administrator /active:yes and press Enter.
3. To Disable the Hidden Built-In Administrator Account -A) In the elevated command prompt, type net user administrator /active:no and press Enter.
4. Close the elevated command prompt.
5. Log off, and you will now see the built-in Administrator account log on icon added (enabled) or removed (disabled) from the log on screen
Computers & Internet Logo
checkdisk /r will not run due to insugfficient priviliges
You should run the command from an Elevated Command Prompt. Running the Elevated Command Prompt is running the Command Prompt with administrative privileges. To run elevated Cmd, right click on Command Prompt or cmd and select run as administrator.
Hope this helps, Mrityunjay.
Jun 27, 2012 | Samsung N150 Netbook
winclonisuneadable
To run Disk Check facility, you must run elevated command prompt and type 'chkdsk' and press enter. Now windows itself will try to figure out any problems related to your hard disk.
Note: To run elevated command prompt, go to "cmd" or "Command Prompt". Right click over it and select "Run as administrator". Now the window of command prompt in administrator mode will open.
Hope this helps,
Mrityunjay.
Jun 03, 2012 | Samsung N13013B Netbook
it boots up but the screen doesnt come on what is wrong with it
hi
To help resolve this issue, use the System File Checker tool (SFC.exe) to determine which file is causing the issue, and then replace the file. To do this, follow these steps:
  1. Open an elevated command prompt. To do this, click Start, click All Programs, click Accessories, right-click Command Prompt, and then click Run as administrator. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  2. Type the following command, and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
Hope this helps you. Let us know either way. Make it a great day!
Jun 13, 2010 | Gateway MT3422 RTL Notebook
user password frozen windows 7 when i boot the PC it requires the password but then opens to a non-registered user who can't save any documents and who has no access to my own files
3. To Disable the Hidden Built-In Administrator Account - A) In the elevated command prompt, type net user administrator /active:no and press Enter.
Feb 07, 2010 | Acer Aspire 5500 5570-2609 Laptop
error8007000b
Here's a fix for Windows Vista Update Error 8007000b and it works (I tried it)
1. Open an Administrator command prompt by right clicking on Start -> All
Programs -> Accessories -> Command Prompt and selecting "Run as
Administrator" and clicking "Allow" for the elevation prompt
(or use run->cmd)
2. In the command prompt, type the command below
cd\
3. Then type fsutil resource setautoreset true c:(If your vista installation is in C: drive)
4. It should say it was done successfully
5. Reboot your system
Jan 16, 2009 | HP Photosmart C6180 All-In-One InkJet...
143 people viewed this tip
David Payne
David Payne
