Tip & How-To about Cell Phones
Samsun Impression SGH-A877, Phone Information
To get your phone infomation, follow these steps:
1) Menu
2) Settings
3) Phone information
from there, you will get the information, you number, manufacturer, model, device id/imei #, and your software version.
Hope this will help for those individual who owns this phone.
Cell Phones Logo
settings for apn are blank. what is my apn code
Hi Edward,
Here are the steps..
Internet Setup
Step 1: Enter Settings
Step 2: Select Wireless & Networks
Step 3: Select More...
Step 4: Select Mobile Networks
Step 5: Ensure Data Enabled is checked (enabled).
Step 6: Select Access Point Names
Step 7: Create a new APN (Select Menu, followed by New APN). Enter WIND Data as the name for the new APN. Under the headings APN enter internet.windmobile.ca (leave all other fields blank).
Step 8: Save the APN settings by selecting menu and then save.
Picture Messaging (MMS)
Step 7: Create a new APN (Select Menu, followed by New APN). Enter WIND MMS as the name for the new APN. Under the following information in the listed headings:
  • APN: mms.windmobile.ca
  • MMSC:http://mms.windmobile.ca
  • MMS Proxy: 74.115.197.70
  • MMS Port: 8080
  • MCC: 302
  • MNC: 490
  • APN Type: mms
  • Leave all other fields blank.
Android 2.1 to 2.3
Internet setup
Step 3: Select Mobile Networks
Step 4: Ensure Data Enabled is checked (enabled).
Step 5: Select Access Point Names
Step 6: Create a new APN (Access Point). Enter any name you would like to call your internet connection and the access point as internet.windmobile.ca (leave all other fields blank).
Picture Messaging (MMS) setup
Step 6: Create a new APN (Select Menu, followed by New APN). Enter WIND MMS as the name for the new APN. Under the following information in the listed headings:
  • MMSC: http://mms.windmobile.ca
  • MMS Port: 8080
  • MCC: 302
  • MNC: 490
  • APN Type: mms
May 10, 2016 | HTC 7 Surround T8788 Windows 7 Wm 3.8"...
need the steps to perform a master reset on the a Sprint Sanyo Pro 700
It is important to know that resetting your phone would wipe out all the data that you hvae on the phone. It is therefore advised that you create a back-up before proceeding.
Steps to Reset Settings
Resetting the default settings restores all the factory defaults, including the ringer types and display settings.The Contacts, Call History, Calendar, and Messaging are not affected.
1.Press Menu > Settings > More... > Security.
2.Enter lock code.(The default code is last 4 digits of your phone number or 0000 or 1234).
3.Select Delete/Reset > Reset All Settings.
4.Read the disclaimer and press OK (left softkey).
5.If you are certain that you would like to restore all the factory settings, press Yes (left softkey).
Steps to Reset Phone
Resetting the phone resets all settings, including the ringer types and display settings.This option will delete all data on your phone.
3.Select Delete/Reset > Reset Phone.
5.If you are certain that you would like to reset your phone, press Yes (left softkey).
Hope this was helpful? Please comment for more information and thank you for using FixYa.
Mar 22, 2011 | Sanyo PRO-700 Cellular Phone
instructions to set up speed dial
hi, if the phone you have is a nokia, them follow these steps:
1.click on contact from the menu list on your phone
2.click on speed dials
3.asign numbers to the speed dials
then click on settings on the menu list
1.click on CALL from there
2 scroll down till you get to SPEED DIAL
3. click on ON.
cheers
Mar 07, 2011 | Cell Phones
I have an i9 phone. I live in Australia and I am with Telstra. GPRS not subscribed keeps coming up when I try and go onto the internet. Need help please
I'm with telstra and used these settings. If you get stuck go to
www.i9forum.co.uk and register then go to the mms & sms section some phone do use a slight variation on this below.
Step 1 – WAP DATA Account Setup
1. Go to the following menu “MENU > SERVICES > DATA ACCOUNT > GPRS >
Select an empty Account”
2. Edit the following parameters in the account
a. Account Name=Telstra WAP GPRS
b. APN=Telstra.internet
c. User name=[blank]
d. Password=[blank]
e. Auth. Type=Normal
Exit back to MAIN SCREEN.
Step 2 – WAP Setup
1. Go to the following menu “MENU > SERVICES > WAP > SETTINGS > EDIT
PROFILE > SIM 1 or 2 > Select an empty PROFILE > EDIT PROFILE”
2. EDIT the following parameters in the account
a. Rename Profile=Telstra WAP
b. Homepage=http://wap.telstra.com/wap
c. Data Account=Telstra WAP GPRS
d. Connection Type=HTTP
Proxy Address = 010.001.001.181
Proxy Port = 80
e. User Name=[blank]
f. Password=[blank]
3. BACK then ACTIVATE PROFILE and exit back to the MAIN SCREEN.
4. Your Phone is ready to access WAP and MMS services.
Step 3 – MMS DATA Account Setup
1. Go to the following menu “MENU > SERVICES > DATA ACCOUNT > GPRS > Select
an empty Account”
a. Account Name=Telstra MMS GPRS
d. Password=[blank]
3. Exit back to MAIN SCREEN.
Step 4 – MMS Setup
1. Go to the following menu “MENU > MESSAGES > MMS > MMS SETTINGS >
SERVER PROFILE > SIM 1 or 2 > Select an empty Account”
a. Rename Profile=Telstra MMS
b. Homepage=http://mmsc.telstra.com:8002
c. Data Account=Telstra MMS GPRS
Proxy Address = 010.001.001.180
Proxy Port = 80
f. Password=[blank]
Feb 12, 2010 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Samsung BlackJack sgh-i607 turned on yet reads ''phone off''
Follow these steps in order:
--- Enter the following exactly: *#1546792*#
--- The following menu (or something close) will appear:
1. Version
2. Preconfiguration
3. NETWORK & CALL SETTINGS
4. Internal
Simply press the number '3' on your keyboard or scroll down and select NETWORK & CALL SETTINGS.
1. Auto Answer
2. Power on Attach
3. Service Domain
4. Network Order
5. NETWORK MODE
Simply press the number '5' on your keyboard or scroll down and select NETWORK MODE.
--- The following options will appear:
Auto
GSM
WCDMA
Select AUTO
--- Press the red key to exit the menu.
You should see the phone acquire service and update the date and time.
Dec 07, 2009 | Cell Phones
141 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
