Tip & How-To about Computers & Internet
When you have messed up wiring your motherboard..
It is easy...
remember this your motherboard is like a children play house red for red, square for square.. if it is not compatible for the socket it will never be placed well..
you need to connect the following..
first your main power supply to your motherboard
it is very easy to see.. it is a group of maybe 16 wires in a plastic connector..you will connect it to your motherboard..
your processor power is a four wired in plastic connector but it is square in shape..
note: take a good look in each connector they have squares cirlce, etc shapes in each wires so don't force it to connect if it is hard to it means it is not for that socket..
this is the turning point..
your power button, reset button, pw LED, HDD LED,
maybe you know where it is placed,
but note the sequence.. pw button, reset, pw led,hdd led,
if not you can try to short the pins of *********** board so that you will know where the power button will be placed...
your usb and internal speaker has their own pins....
note: take a good look to your motherboard before you connect it, it may cause you some trouble..
take a look at the + ,- signs that is encrypted in the motherboard...
you have to the red wire is fore the posite and the black is negative..
i know it is compose of four wires but they are in one socket right...
your hdd connect it i know you know that how..
that's all..
Computers & Internet Logo
Are plastic bags dangerous with children around? My neighbor doesn't allow plastic bags in her house because her kids are young. Is she right?
Plastic bags can be a choking or suffocation hazard if children are allowed to play with them or access them while they are unattended. This doesn't mean you can't use plastic bags in your house but it's a good idea to have a secure plastic bag holder to store them safely away from kids.
Apr 22, 2013 | Retail Supplies
what is the processors that can be compatible for Intel motherboard
Confirm your motherboard's compatibility with the Intel CPU you want to install. Motherboards typically only support one type of CPU slot, so purchase an Intel processor that is compatible with that slot.
Ensuring your processor and motherboard are compatible is vital when choosing parts to build your own computer system. If they are both the same socket type, they will most likely work together.
Brands
There are a plethora of motherboard manufacturers, but only two main processor manufacturers: AMD and Intel.
Every motherboard, regardless of manufacturer, has a socket that will accept a processor.
Intel
Common Intel socket types include LGA775, LGA1156 and LGA1366. Older models include PGA370, PGA423 and Socket 479.
Your motherboard and processor will be generally compatible if their socket types match. ...
Intel Core 2 Quad Q9650 Processor Compatible Motherboards
Hope this will help you and please don't forget to rate me. Thanks for using FixYa
Aug 02, 2011 | Intel Motherboard
5 socket mother board using 2800+ processor failed. Can i get a compatible mother board.
yes you can! compatible motherboards are cheap and easy to find for the socket 754 design compatible with your cpu. with prices going from anywhere from ~$50-$80. great places to shop include frys electronics, newegg.com, amazon.com and tigerdirect.com. when something like this happens to you its always a good idea to consider upgrading your computer as well you can find cpu motherboard deals anywhere from $100 to $200 with a huge boost in computing power. if you choose to go this route make sure your ram will work on the motherboard you are considering. goodluck
Mar 05, 2011 | AMD Athlon-64 2800 CPU and Mother Board...
I DISCONECTED ALL MY CABLE SO NOW I CAN'T ABLE TO CONNECT THE WIRE BECAUSE I LOT MY BOARD CHART
it is easy...
that's all..
Feb 07, 2010 | ASUS P5PE-VM Motherboard
different types of processors available in the market.
Remember, when buying an Intel socket 775 processor, not all socket 775 based motherboards support all socket 775 processors. So don't buy one without first checking compatibility. Not the same case with Socket AM2 for AMD processors, these just plug and play. Need more help? visit my website at http://www.motherboardsrus.net
Jun 07, 2009 | Intel Computers & Internet
246 people viewed this tip
David Payne
David Payne
