Tip & How-To about Computers & Internet
Partition problems in pc...
If you are experiencing some problems about the size of your hard disk because of imbalance partition or lack of free space..
there are many application now that can help you...
some are called partition magic, partiton manager...
you can check out here ad download a partion magic..
here is the site check it out...
http://www.partition-tool.com/partition-magic/magic-partition-download.htm
if you want a direct down load hre is the link
http://download.cnet.com/Easeus-Partition-Master-Home-Edition/3000-2248_4-10863346.html
i hope its a help...
Computers & Internet Logo
How can I extend my C partition to remove its low disk space problem?
The partitions D,E and F may system partitions for tools like system restore and diagnostics. I would suggest removing some stuff from C:, if that is not an option you could consider a hard drive upgrade.
Oct 17, 2014 | Computers & Internet
solution of low disk space
HARD DISK MAINTENANCE TO KEEP COMPUTER RUNNING EFFICIENTLY.
Hard disk maintenance should be carried once a month to make your computer run efficiently.
This removes redundant and temporary files, recovers disk space and speed up hard disk access.
Disk Cleanup should be done first - Click My Computer - then right click on the C drive then click Properties, then click Disk Cleanup - let it examine the C drive then it will calculate the amount of disk space it will recover, tick all the boxes to recover the maximum disk space and then Click OK and then Yes to perform these actions. If you have a D drive then repeat these steps on this drive too.
Next the C drive needs to be Defrag. This process converts fragmented files into continuous files and this speeds up disk access and makes the hard disk not work as hard. Click on Start - All Programs - Accessories - System Tools - Disk Defragmenter - click to highlight the C drive and click Analyse - then click Defragment.
When this is completed repeat these steps for the D Drive if you have a D drive.
Disk Cleanup and Defrag can take a long time to complete, especially if these tasks have not been for a long time.
May 12, 2013 | Dell Inspiron Computers & Internet
MY C drive Booting drive is 30GB, in side c drive file properties is showing 20GB bt free space is showing 2GB
Its probably formatted not to use the entire space of the disk, is there another partition or "D" drive where your restore/backup stuff is? That could be take up the rest of the space. Hard disks are always described as being a certain size but can be formatted by windows tlo split up the drive into smaller chunks called partitions. Your C drive/partition might be way less then 30Gb therefore only showing up as 22Gb
May 17, 2009 | Smartdisk - Peripherals - HARD DRIVE,...
lack of memory space
You can adjust the size of the partitions with:
EASEUS Partition Manager (free)
http://www.partition-tool.com/download.htm
Jan 15, 2009 | Compaq Evo D300 PC Desktop
Seagate drive partition
This is fairly straightforward using the Windows XP tools.
IMPORTANT, copy everything you want to keep from partition F otherwise it will be deleted. Drive G will not be affected.
  • Right click 'My Computer' >'Manage' then click disk Management.
  • Right click your drive F and 'Delete Partition'.
  • You now have 210GB unused space on the drive.
  • Right click the unused space and "Create Partition".
  • Specify the size of the new partition to your requirements or create more partitions until the free space runs out.
  • You can then right click and format the new partitions. 'Quick Format' is fine unless you have been experiencing disk problems.
To swap around drive letters in Disk Management:-
  • Right click the drives and 'change drive letters', to X, Y or Z or whatever
  • Now you can change the drive letters back to F, G, H or whatever order you want them in
I'm sure you get the idea, you just have to change the letters of the drives to unused letters to make a space in the sequence (not that any sequence really matters)
Good luck
Nov 08, 2007 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
264 people viewed this tip
David Payne
David Payne
