Tip & How-To about Computers & Internet
Windows error messages
"Operation has been cancelled due to restrictions in effect on this computer"
start >run>regedit
go to: REGEDIT - registry editor
When in registry editor: HKEY_CURRENT_USER – right click for permissions
Advanced Security Settings under 1st tab permissions
You will probably get this error message, "You can't remove restricted because this object is inheriting permissions from its parent.
To remove restricted, you must prevent this object from inheriting permissions. Turn off the option for inheriting permissions, and then try removing RESTRICTED again.
· Unclick: include inheritable permissions from this object’s parent
· Windows security warning: options to add/ remove/ cancel
· Click Remove inherited parent permissions
Denied all access
Continue – delete restricted
Once removed,
Follow this path in registry editor:
HKEY_CURRENT_USERS\software\classes\.html
Right click (Default)
Change value data from (in my case Chrome – it could be Firefox as well):
Repeat steps for .htm, .shtml, .xht if they exist
RESTART COMPUTER
Computers & Internet Logo
wat does regedit means
regedit is an an inbuilt Microsoft Registry Editor. To start the regedit.exe go to Start>>>Run>>> type regedit and click OK. The Microsoft Registry Editor (regedit.exe) enables you to view, search for, and change settings in your system registry, which contains information about how your computer runs. Although you can use Registry Editor to inspect and modify the registry, doing so is not recommended, because making any incorrect changes can damage your operating system. Please go to http://en.wikipedia.org/wiki/Windows_Registry for more details.
Mar 22, 2012 | Acer Computers & Internet
How to restrict user's to access shutdown button
Follow the given steps to hide system shutdown button from start menu:
To use this feature, you will need to be logged into your computer with administrative rights.
1. Click Start button and type regedit in Run option then press Enter for next.
2. Here locate the location to:
HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion \Policies\Explorer
3. Here in right side panel, right click to create a new DWORD value with name NoClose.
4. Now assign number 1 to its value data box. Now close the registry editor and restart your computer after any changes to go into effect.
5. But next time, if you want to unhide the shutdown button then simply change the value data box to 0 or delete this DWORD item.
6. Again close the registry editor and restart your computer after any changes to go into effect.
Jul 10, 2009 | Microsoft Windows Server 2003 Enterprise...
regedit restricted
regedit can be done only if u login to the computer as the administrator....
thank you  have a nice day
May 06, 2009 | Computers & Internet
I am trying restore windows vista on my ACER Aspire 5100 but a message keep coming up saying that Windows cannot open the required file D:SourcesInstall.wim. It also says the file does not exist and to make sure all files required for installation are required and I get the error code 0x80070002
This error is due to....
  • The default security provider in Windows XP, or
  • the System drive letter
  • To solve dis issue.. try one of the methods
    1)Reset Windows XP Default Security Provider
    1. Open Start menu, select Run, type regedit and then press Enter.
    2. In the Registry Editor window, locate and delete the following registry keys:
      HKEY_USERS\.DEFAULT\Software\Microsoft\Cryptograp hy\Providers
      HKEY_USERS\S-1-5-20\Software\Microsoft\Cryptograp hy\Providers
    3. Exit the Registry Editor and restart your PC
    2)Reset The System Drive Letter
    1. Start your computer in Safe Mode-turn on the PC, and press F8 during startup. Next, when the Windows Advanced Options menu is displayed, scroll down and select Safe Mode.
    2. Open Start menu, select Run, type regedit and then press Enter.
    3. In the Registry Editor window, locate the following registry keys:
      HKEY_LOCAL_MACHINE\SYSTEM\MountedDevices
    4. Edit this key to change the value of the system drive.
    5. Exit the Registry Editor and then restart your PC
    Mar 20, 2009 | Computers & Internet
    285 people viewed this tip
    David Payne
    David Payne
