Tip & How-To about Cell Phones
Various tips
SOLUTION: Hold On/Off switch until it resets
SOLUTION: Turn Off iPhone; Power it back up
SOLUTION: : Reset TomTom One at least once, Sometimes several times to power up
SOLUTION
  • Ok... there is a trick to this. I set it up EXACTLY the same way with the AT&T option and the Cingular option. The only way it works is with the CINGULAR option.
1.replace the APN isp.cingular with
wap.cingular
2.delete default username, type WAP@CINGULARGPRS.COM
3.delete default password, type
CINGULAR1
4.when the login script comes up it should look
ike this (because you've already changed the APN)
at+cgdcont=1,"IP","wap.cingular"
5.Accept the automatic configuration for the IP & DNS
Cell Phones Logo
My phone can't connect internet
Your phone might be having some connection problems restarting it should fix it here are some different ways to restart the phone if it still does not work with one way try the other:(It can also be relate to your network maybe low signal or no reception at all)
Reboot:
1) Turn on iPhone.
2) Hold Sleep/Wake button (top right) until a red slider appears and says Slide to Power Off.
3) Slide the red slider.
4) Once the chasing lines are gone and the screen is black, hold the Sleep/Wake button for about 2 seconds. Your iPhone is now rebooting.
Hard Reset:
1) Power iPhone on.
2) Hold the Home and Sleep/Wake buttons for about 7 seconds, or until the screen turns black.
3) Your iPhone should reboot. If it doesn't don't worry, just hold the Sleep/Wake button for about 2 seconds.
Restore:
1) Connect to iTunes.
2) Allow your iPhone to back up and finish the sync.
3) In the Summary tab, click the Restore button.
4) Click Restore and Update to the confirmation message that appears.
5) Follow on-screen instructions from there on.
Feb 26, 2011 | Apple iPhone Apps
I cant get my phone to turn on everytime I hold the reset button the apple logo appears for 5 secs then the screen turns black.
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Nov 30, 2010 | Apple iPhone 3G
Iphone will not turn on, if I connect it to my computer it makes a noise but nothing happens on the screen, I have tried holding down the on/off and the home buttons.
Reset
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Nov 12, 2010 | Apple iPhone Smartphone
lcd
try rsetting the iPhone:
Reset
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Jul 24, 2009 | Apple iPhone Smartphone
Black DSi frozen.
Everyone i just found out how to fix a black or white dsi that is frozen and wont turn off!!
Step one:unplug dsi (if it is charging)
step two:close the dsi
step three:once it is closed turn volume down all the way witout opening
step four:set the dsi in front of a fan vent or someplace it will get a breeze
step five:open the dsi and hold power switch for like 6 to 10 seconds
(even when it turns off keep holding it for a couple more seconds)
now you an plug it back in and turn it on and VAWALä
hope this helped:)
Jan 02, 2009 | Nintendo DSi White Console
446 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
