Tip & How-To about GPS
Reset you TomTom password.
To reset your TomTom device, do the following:
1. Check that the battery is charged properly.
Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
2. Remove the SD card
If your device uses an SD card, remove it.
3. Reset your device.
Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
4. Turn your device on.
Press the On/off button for at least 5 seconds.
5. Insert the SD card
If your device uses an SD card, insert the SD card.
GPS Logo
Im locked out and I cant remember the password my brother set up for me what do I do to unlock my tom tom one?
To reset your password try this. To reset your TomTom device, do the following:
Feb 07, 2010 | Tomtom ONE XL GPS
how do you reset the tomtom one
There are two method depending on which version of the Tom Tom One you have (there are a few).
Method one
  2. Reset your device.
    Press and hold the On/Off button until your device comes on - shuts off and restarts. This can take more than fifteen seconds.
Method 2
Check the bottom of the unit to see if it has a Reset button which is recessed into a hole in the casing like this
If so follow this procedure;
Hope this helps. Please do take a moment to rate the answer. Thanks.
Jan 23, 2010 | Tomtom ONE GPS Receiver
how do you reset the whole entire thing?
To reset your TomTom device, do the following: (From the Tomtom FAQ)
Jan 03, 2010 | Tomtom ONE GPS Receiver
Tomtom1 keeps restarting itself
try resetting it, if that doesnt work, connect your unit to tomtom home. if you dont have tomtom home, follow the link at the bottom.
Aug 20, 2009 | Tomtom One XL GPS Receiver
my go 720 gps keeps freezing up
Aug 20, 2009 | Tomtom GO 720 GPS Receiver
257 people viewed this tip
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
