Tip & How-To about Nintendo DS Lite Console
DS Lite microphone repair tips.
If your built in microphone on your DS lite is not working then there are
5 things I can suggest for you before you go ahead and buy a new one for replacement.
1) Make sure your volume is up, you may not be hearing it picking up (sounds obvious but worth a try).
2) Use a wooden coctail stick or similar and CAREFULLY remove any lint/fluff that may have collected in the mic slot (be careful not to dig too deep as this will damage the mic).
3) Use a hairdryer on a low setting to dry out any spittle that may have collected in the mic (please be careful not to let the ds get too hot as this will cause serious damage).
4) Test your external mic port by either connecting a mic if you have one and if not get a slither of metal (such as a sewing needle or small/precision flat-head screwdriver) and give it a wiggle in the mic port. (the mic port is the rectangled hole with two metal pins in it net to the 3.5mm headphone jack), if you get a reaction thats a good sign and shows that, if it comes down to it you can use an external mic until you get the problem sorted.
and finally...
5) I must stress that this last tip requires you to have a steady and gentle hand... plus a bit of congidence :).
Use a sewing needle or pin to gently pry the two metal pins in the mic jack upwards, the front of the pins are fixed but further back the pins float, you need to raise these enough to sever the connection these pins are making as when these pins are making a connection they over-ride the internal mic.
If all these five tips fail to work for you then your only option is to replace the microphone, it can easily be done with basic/moderate D.I.Y skills. A replacement DS lite microphone is readily avaliable and cheap on ebay. If you need help with a microphone replacement please feel free to contact me and I will do my best to help you out.
I hope this helps and would like to say I accept no responsability for any damage that may occur to your ds lite when following my tips.
Regards,
SOD69
Nintendo DS Lite Console Logo
My ds lite touch screen works in some areas but not in the middle do i need it replacing
Try to calibrate the screen again and if that doesn't work then chances are you will need to replace it.
If its under warranty then send it off, if not you can either take it to a repair shop or do it yourself.
If you do want to do it yourself I would suggest trying disconnecting the touchscreen and then reconnecting it before you go ahead a buy a new one just incase its the connection thats wormed its way loose.
If you need a guide for how to take the DS lite apart including what tools you will need I have one written up on here.
Dismantling A DS Lite
Feel free to message me if you need any help.
Regards,
SOD69
Feb 09, 2010 | Nintendo DS Lite Console
microphone on ds
Hi - we had the same problem on ours - caused by overenthusiastic blowing (with spit!!!!) microphone shorts out. If shorted at mic it is easily fixable - do as we have done and buy a Game earpiece and mic combined for about a fiver. If it has shorted at motherboard, you need a new one.... sorry...
Feb 15, 2009 | Nintendo DS Lite Console
brain training microphone isnt working any tips?
Try and buy the Nintendo DS Headset. I had the same thing, but I did that and it worked.
Jan 13, 2008 | Nintendo DS Lite Console
1,461 people viewed this tip
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
