Tip & How-To about Cameras
DIGITAL CAMERA MAINTENANCE
Charge battery after every use
always remove battery when not in use
be smooth while inserting and removing usb cables
keep clean the camera case (leather cover / cloth cover)
never keep digital camera in your pant pocket (back pocket)
gently clean barrel unit (lens assy) before switch off digital camera
Cameras Logo
I keep getting the message "connecting to computer" on Samgsung SH100
Disconnect the camera, remove the battery and after a few moments reinsert the battery. Then switch on again.
When you charge the battery in the camera, the camera could think it is connected to a PC, because the USB cable is inserted. It could be you are using a USB cable, that not came with the camera. If the error keeps coming back buy an external (Universal) charger, to charge your battery. Modern universal charges can charge almost every camera battery on the market. In the long run, it is better for the camera and for the battery, when you charge in an external charger.
Keep the contacts clean with a dry cloth.
May 10, 2014 | Samsung Sh100 black 14.2mp 5x Zoom Digital...
i can´t switch my camera on and i also can´t recharge the battry throw usb
The camera doesn't charge though the camera is on. It only charges when the camera is off. Here are the steps for no power problems: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 15, 2010 | Kodak V803 Digital Camera
my camera cant charge if I put it on the light it dosen't CHARGE EVEN IF I PUT MY USB CORD WHAT SHOLD I DO?
Please note that the camera will only charge from the computer if the camera is turned off. Also try a different USB plug. 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 09, 2010 | Kodak EasyShare M863 Digital Camera
ASpire 5580 series, no power
Hi Dhadha,
Try this: - remove AC adapter plug - remove the battery - insert the battery again. - try power up the laptop.
I have same problem, but this trick always work, and I always do this every power up. :)
However, I am using a usb optical mouse for an indicator. When inserting the battery, I check the light on the mouse. If it is flashing the second I insert the battery, then the power up will be successful. IF it is not, then remove and insert the battery again.
Try it.
Regards,
Dapid Candra
Nov 17, 2008 | Acer Aspire 5580 Notebook
General USB Troubleshooting
While USB connections are significantly faster and easier to set up than older serial or SCSI connections they are not foolproof. Here are some tips: Be sure to connect the cable properly One side of the cable is "keyed" so it will only fit properly one way. Do not force it in if it does not smoothly connect. Notice how the USB plug is "keyed" and will only fit properly in one direction. The USB connector on the back of the computer. Connect directly to a USB port on the computer. While USB hubs allow many devices to connect to a computer they are not always reliable for high-speed connections like digital cameras. Connect to a port on the back of the computer. Many computers have extra USB ports on the front or on the keyboard. These are generally built-in hubs which may cause problems as described above. Connect to an AC adapter or use a freshly charged battery To prevent problems during transfer be sure that the camera has enough power to complete image transfers. Remove other devices To troubleshoot problems, remove any other USB devices and connect just the Nikon product for testing.
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
155 people viewed this tip
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
