Tip & How-To about Activision Guitar Hero
Guitar Hero Drum Set Common problem
Hello guys, i just wanna share with u one of the most annoying problem in the drums its the pedal, some times while u r playing on guitar hero drums hiting the notes its suddenly start kicking the pedal by it self and u cant continue playing because of that, what i want to tell u that before u react to that by start opening the pedal to fix it, you should first make sure that the pedal itself is damaged or not. just follow the steps ok.
1- remove the pedal and replace anything on the behalf of it like your headsets, just put anything in its place on the drums location and start a game and play and hit on the drums as hard as u can and see if the pedal is still kicking when ur hitting the red, green, blue drums if YES then its not the pedal its the drums itself, if not then u have to fix the pedal, i will tell u how later ok. 2-now after using some other device and finding that the pedal is ok and ur having this problem, just flip the drums and remove all the screw at the back ( trust me its so safe and easy) now open the drums and and go to the place where the pedal made to fit in u will see a chips and a screw in the middle, just screw lift ( most of times while ur playing and because of the heavy hitting on the drums the screw get relaxant so all u have to do is tight it up very well and it will solve the problem. 3- get everything back as it was and enjoy good and AWESOME play like if its brand new drums :))) hope i was very helpful
and about fixing the pedal if it was damaged flip and remove the first gray label its some kind sticky but its ok just remove it and u will find 2 screw remove then and go back to the front where the wire goes inside the pedal push it inside and then push it up it will be removed and there u will find 2 wires they may need to get fixed its easy weld the damaged wire and everything is ganna be FINE
Activision Guitar Hero Logo
I have guitar hero 3 on xbox 360 along with the wireless drums (cymbal and hi hat) and the wireless guitar. I can not get them to play together. The guitar plays but I can't get the drums to play. do I need the foot pedal?
Unfortunately, Guitar Hero 3 does not support drums. World Tour is the first game in the series to support them. In addition, if they aren't official Guitar Hero drums, they aren't guaranteed to work with World Tour. Hopefully they do work. Good luck!
Mar 14, 2011 | Activision Guitar Hero III: Legends of...
drums and guitar swapped over on ps3 guitar hero
just use the guitar as drums & use the drums as a guitar... nah just jokes you won't be able to fix that unless you get some pro guy to repair but it'll cost you around the same price you brought it. goodluck though...
Jun 06, 2010 | Activision Guitar Hero
i figured it out
check this link for a complete matrix of which instruments work with which games on which consoles http://www.joystiq.com/Instrument-Compatibility-Matrix/
Feb 04, 2009 | Nintendo Guitar Hero Wireless Guitar - Wii...
do not know how to use starpower on drums
You have to hit both cymbals at the same time.
Nov 21, 2008 | Activision Xbox 360 Guitar Hero II
879 people viewed this tip
Top Activision Video Game Consoles & Games Experts
Zhenya Ogorodnikov
James Wishart
ray gallant
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
