Tip & How-To about Sony Playstation 3 (PS3) Console
How to update to 3.15 on PS3
If you are stuck on downloading the update here are a list of ways to fix it
1.Download the update on a USB stick
2.Restart your router
3.Use an ethernet cable to connect
4.Turn off the UPNP When setting up a connection or vice versa
5.Keep downloading the update VIA PS3 Sometimes it does it in chunks
6.Transfer the Update VIA PS3 to PS3
7.Try system restore
8.Try all the restores E.G system restore, game restore
9.Use a differnt router
10.Try it of somebody elses connection E.G friends, grandparents.
Sony Playstation 3 (PS3) Console Logo
fix code 3141 3151 b200 0700 c000 0013 help me fix please .
Did you download the 12625 update from Microsoft and try it from USB? More info please, was the box modded in any way? The update you need is not the latest by far. Download update 2.0.12625.0 here
1 Plug your USB flash drive into a USB port on your computer.
2 Download the update file.
3 Click Save to save the console update .zip file on your computer.
4 Unzip the file. If you are using Microsoft Windows XP, Windows Vista or Windows 7 or 8, double-click the .zip file to unzip it.
5 Copy the contents of the .zip file to the root directory of your flash drive.
6 Unplug the USB flash drive from your computer.
7 Plug the flash drive into a USB port on your Xbox 360 console.
8 Restart the console.
When the console restarts, the installation program starts automatically. Select Yes when you are prompted to update the new console software.
Hope this helps
http://download.digiex.net/Consoles/Xbox360/Dashboards/2.0.12625.0.zip
Jan 29, 2015 | Microsoft Xbox 360 Console
www xbox com support
Cause that game needs a new dash.Check what dash you are currently on by going to system settings and system info you will see the kernel there .it most likely is an old version so download this one( http;//download.digiex.net/Consoles/Xbox360/Dashboards/2.0.16747.0.zip)
1.) Unrar the download (i use winzip)
2.) Copy the $SystemUpdate folder to the root of a pc formatted USB Stick (The memory stick must be FAT or Fat32 formatted)
3.)With that extracted folder now on your USB, Insert the USB Stick into your Xbox 360 console.
4.) You will be automatically prompted to update with a USB stick. Power down the 360 and power it on again. You should be ask to update before the 360 boots to the dashboard.Click yes and wait for it to install then shut down.
5.) Once the update is complete your Xbox 360 will restart then boot up to the new dashboard.
Aug 06, 2014 | Activision Video Game Consoles & Games
i want to charge the battery from the pc?
Linux-based Acer Aspire One Non-Charging Battery Solution
STEP 1: On a separate PC:
1. Go to www.support.acer.com or http://gd.panam.acer.com/home/
2. Click on Driver & Downloads
3. Select Product Family “Netbook”
4. Select Product Line Aspire One
5. Select your Product Model i.e.: AOA150 (located under your computer, after MFG.Date:xxxx AOA 150 – xxxx)
6. Click on the BIOS tab below (don't worry if you don't see Linux listed – BIOS is OS-independent)
7. Download BIOS to a temporary folder on your PC
8. Extract and make sure you know where you put the extracted files. You will only need three of them.
STEP 2: On a separate PC:
1. Ensure a USB memory stick is plugged in and run UNetbootin by downloading and running from: http://unetbootin.sourceforge.net/
2. It will prompt for a “Distribution” – change this to “FreeDOS”.
3. At the bottom of the window ensure the “Type” is “USB Drive” and check the “Drive” is the drive letter of your USB memory stick.
4. Click on “OK” and FreeDOS will be installed onto the USB drive. At the end don't Reboot.
5. Now copy some of the extracted BIOS files onto the USB drive as well. The only files you need copy are three: go to the sub folder BIOS_ACER_3310_Windows_AOA110 & AOA150/Dos_Flash, and copy the files 3310.BAT, 3310.fd and FLASHIT.EXE to the USB stick
6. Remove your USB stick from the PC, and plug into into your switched-off Acer.
STEP 3: On your Acer:
1. Reboot the Acer and press F2 at the initial “splash screen” to go into the BIOS settings.
2. Once in the BIOS arrow across to select the Boot Menu and move the USB HDD to the top of the list (using F5 and F6 to move them up and down). (I also moved USB FDD and USB CD-ROM)
3. Press F10 to save and exit.
4. Your Acer should now boot from the USB stick.
5. The FreeDOS screen will appear with an option to select a default option. Do this.
6. You will now be presented with a list of boot options – select option 5 (FreeDOS Live CD).
7. You'll get an error message about missing CD-ROM, which you can ignore and you'll be at the DOS A: prompt.
8. At the DOS prompt go to the B: drive (i.e. type “b:”, without quotes, and hit enter – the B: drive is you USB stick) and run the the 3310.BAT script (i.e. type 3310.BAT, without the quotes, and hit enter.
9. The BIOS should now install and reboot your Acer. Click on Settings and then System to check your BIOS has updated.
10. Restart your Acer and repeat 1. and 2. above just to make sure the Boot priority order has your hard drive at the top of the screen. It will probably have reverted automatically to the original order. If not, use F5 and F6 to put back in the original order.
These are a combination from:
http://chunkmedia.co.uk/2009/09/23/acer-aspire-one-update-bios-using-linux/
http://www.netbooktech.com/tag/acer-aspire-one-bios-update-instructions/
http://www.artiss.co.uk/2009/02/acer-aspire-one-bios
Aug 11, 2010 | Sony Ericsson Walkman W205 Cell Phone
i downloaded windows 7 now I can't use my d link usb connector plus my bell wireless connect is no longer picking up any wireless signals
1. check the compatibility list for Windows 7
2. check the manufacturer's site for firmware updates for your router.
3. try moving the router . If the router is near a cordless phone or microwave move it 6 to 8 ft away from this device.
4. go to http://support.dlink.com to download the latest firm ware update.
from the manual :
Click on the link in this screen to find out if there is an updated firmware; if so, download the new firmware to your hard drive.
After you have downloaded the new firmware, click Browse in this window to locate the firmware update on your hard drive. Click Save Settings to complete the firmware upgrade.
Apr 21, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
how to update
call 1-800-243-0000 and they will send you an upgrade
Feb 02, 2009 | LG Super Blu BH200 Blu-ray and HD-DVD...
594 people viewed this tip
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
