Tip & How-To about Brother DCP-340CW All-In-One InkJet Printer
DCP-340CW MACHINE ERROR 46 the Photo Capture and red exclamation mark lights flash slowly.
Clean the ink overflow pads you will have to almost take the printer to bits, they are underneath the print head dock position, these cost about £25
In the mean time you can RESET this purge count back to zero using theMAINTENANCE 80 menu, to continue using the printer for a while untilyou get the new pads. But it on a tray as if they are full they maystart to leak onto your desk....
1 . Press (MENU) (MONO START)then (^) OR four times, the Photo Capture and RedExclamation Lights will then flash.
2. Press (^) eight times until you see <8> then press (SET)
3. Press (^) twice until you see <0> then press (SET)
You will now be in MAINTENANCE 80.
4.Press the (MONO START) its a toggle until you see PURGE:6451 ( I guessthis means you have cleaned the heads over 6,450 times their thresholdlevel.) you will need to enter the code <2783> to RESET it.
5. Press (^) twice until you see < 2 > then press (SET)
5. Press (^) eight times until you see < 7 > then press (SET)
5. Press (^) nine times until you see < 8 > then press (SET)
5. Press (^) four times until you see < 3 > then press (SET)
The Printer will beep then reset counter will be at ZERO <0000000>
Its the PURGE that will increment by a variable amount each time youclean the print heads the amount will be between 100 and 130. When thiscount gets to about 64,000 the error 46 will occur. That's about 510times you can clean the heads before the pads need cleaning.
Almost forget to EXIT the Maintenance mode enter 9 twice by using theup arrow & set key's to exit from maintenance mode in the same wayas entering the 2783 code, or power down the printer.
Brother DCP-340CW All-In-One InkJet Printer Logo
kodak esp 7250 printhead carriage jam
This problem has plagued me for a very long time. The issue is that the printer head is "glued" in the resting position under the guard of the printer, so you can't remove the ink cartridges to clean it. Solution is to (I know this sounds stupid, but it works) turn the printer on the side where the printer cartridges are (if they are stuck on the left side, turn the printer on its side so the cartridges are on the bottom). Turn the printer on, and the cartridges magically start moving! I guess there are some sensors that get tricked out when you tip the printer on its side. If the cartridges are still stuck, click the "ok" button, and before it gets a chance to see if you actually fixed the problem, turn the printer off using the power button. It takes a long time, but you should see the ink trap lower (release the ink cartridges) and the ink cartridges start moving to prepare for shutdown! Grab the cartridges when they move out of their hiding place and don't let them go back until you clean the print head so it doesn't get stuck again. Remove the ink cartridges, then push the grey tab to release the print head. Wipe the bottom of the print head clean with rubbing alcohol (it will have a lot of gooey - sticky ink stuck on the bottom). I used nail polish remover since I didn't have rubbing alcohol available. You can also wipe down the ink pad which is where the ink cartridges were previously jammed to clean up more of the mess and prevent this sort of thing happening again too soon. Good luck!
Mar 09, 2013 | Office Equipment & Supplies
Epson R230 printing unwanted lines
The problem is waste ink around head sprayer (at (bottom plate of head). Turn of printer. Move head to center. Put wet tissue (with hot water) at head cleaning mechanic pad. Move head to parking position. wait till 10 minutes. check it. You can repeat 3 times.
Jun 09, 2009 | Epson STYLUS R230 InkJet Photo Printer
Message says that the ink overflow is full. How do I replace or correct the problem on my Cannon iP 1500?
1) Underneath the print head are 2 foam pads. Turn your printer on with the cover open and then unplug it with the print head away from the pads.
2) The 2 pads have 2 silicone tubes attached to them that run to the rear right side of the printer.
Taking the sides off you can unsnap plastic clips to remove the top half of the printer cover.
3) Follow the silicone tubes. They run into a white plastic pump that sucks the ink that falls onto the pickup screens and dumps it onto numerous felt absorber strips under the pump mechanism.
4) To clean or change the absorber felts you must first remove the Pump mechanism which is held on by 2 screws so that you have access to the felt absorber pieces
5) Run clean water over each piece of felt until the water runs clear and then place them on an absorbant surface (paper towels maybe) to dry.
6) Put it all back together the same way you took it apart.
This can be extremely messy, be careful not to get the ink on anything that matters.
Jun 03, 2009 | Office Equipment & Supplies
The ink well is full and leaking. How do I clean it out.
There is an ink well below the home run position of the print head and cartridge assembly. If you open the lid of the printer, the print head moves to the center of the rail. You then unplug the printer and gently move the print head to the left and out of the way. If you shine a flashlight in the right hand corner or home run position, you will see the ink well. You can clean it out with a paper towel or a syringe. Obviously, the well is no longer overflowing and the drip should stop.
Apr 08, 2009 | HP DeskJet 1220c InkJet Printer
black ink
I had a similar problem with the r320 epson
I found that it had blocked.
this works well to clear the head
1 switch on the printer with the cover open
2 as the cartridge head moves away from its docked position pull the mains plug.
3it is then possible to slide the head to the left .
4 there is a square of flet on the right the head would normally be over, add a squirt of mr muscle bathroom cleaner on the pad ( main off)
5plug the printer back in and the head will return the the docked position.
6 leave for and hour or 6 then try to print
Dec 03, 2007 | Epson Stylus Photo R200 InkJet Printer
3,205 people viewed this tip
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
